Does 300VA + 300VA = 600VA? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th May 2006, 11:10 PM   #1
Cloth Ears's Avatar
Default Does 300VA + 300VA = 600VA?
If you wire up 2 300VA in either of these configurations, are yuo effectively getting a 600VA transformer? Or are you getting a very expensive 150VA? Or a good way of melting copper? or are the figures incorrect and I'm getting an 80V (or a 20V) 300VA?
If this is a valid way of wiring 2 transformers, should they physically be mounted on top of each other, next to each other (flat), or some other orientation (strung from the top of the casing with organic cotton)?
The reason, of course, is money - 300VA (40-0-40) on special for $40; the cheapest 500VA (40-0-40) I can find is $86.15
Raka asked something like this in thread Parallel transformers and bridge, but it didn't specifically answer my question - and I'm looking at an unregulated supply.
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 10th May 2006, 11:45 PM   #2
lndm is offline lndm  Australia
AFAIK, this is valid in theory. As far as physically mounting is concerned, I would keep the xfmrs apart like any others, over the concern of inadvertent magnetic bucking.
Old 11th May 2006, 12:03 AM   #3
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
The resulting VA rating from several transformers connected together is the sum of the ratings of each one as long as the resulting complex connection still involves using all the primaries at their full voltage rating (and obviously all the secondaries).
Secondary windings from different transformers can be only paralleled when the same voltage is granted to appear across them (ie: when both transformers have exactly the same turn ratios and their primaries are fed with the same voltage or when primaries are connected in series thus balancing mutually).
I use to feel like the small child in The Emperor's New Clothes tale
Old 11th May 2006, 12:37 AM   #4
Cloth Ears's Avatar
I'll probably go that way, as I was also keen to avoid 'crushing' the 2 sets of windings together anyway (if they were on top of each other). I'm not sure if there would be "magnetic bucking" (did you mis-spell that word?) with them epoxied together - but I'm open to being persuaded. I'd be able to have 2 power supplies in the one case if I could put them on top of each other - otherwise I'll have to use 2 cases (the caps are 150x75mm ea). I guess this is OK as 2U rack mounting boxes are also on special
The transformers will all be from the same batch and they'll all be being fed from the same source. Looks like I might be getting a cheap 600VA trannie (well, 4, actually).
BTW, thanks for the responses. I wonder if anyone has actually done this?
Jont.
Old 11th May 2006, 12:43 AM   #5
m-a-g-n-e-t-i-c, no I think that's how it's spelled
The transformers only need to be connected electrically to do what you want. Magnetic interference will only hinder them. When mounting them together (which ordinarily I would never recommend), the results wouln't be that predictable.
Old 11th May 2006, 12:44 AM   #6
Eva's Avatar
I routinely use the secondaries of small transformers scrapped from other equipment connected in series-parallel (with primaries in parallel) in order to obtain a low-cost isolated 230V mains source for SMPS work. Note that winding polarity matters.
BTW: You can mount several power toroids in any way you want, stray magnetic fields are low enough to yield any mutual interaction negligible. That does not apply for SMPS transformers, tube output transformers or signal transformers, though.
Old 11th May 2006, 01:17 AM   #7
Cloth Ears's Avatar
m-a-g-n-e-t-i-c,
I can theoretically fit 2 amp boards, 2 soft-start circuits, 4 trannies and filter caps in a 2U rack mount box, with a bit of space to spare. The trannies won't fit on top of each other anyway (114mm), so I won't worriy about that. I'll just get the bits home and see if they fit 'properly'. It doesn't matter if I have to get another couple of cases to get them to fit 'nicely' (and it makes them easier to work in).
Gee, that was an easy decision - monoblocks!
Jont.
Old 11th May 2006, 04:27 AM   #8
kartino is offline kartino  Indonesia
kartino's Avatar
Paralleing transformer shall consider that the transformer are have identically characteristic, such as voltage level, phase error angle, polarity, etc.
For big (utility power company) they must consider harmonics when energizing parallel Transformer. For small transformer like amps power supply, I have no problem experience so far. On text book the primary cable shall have same length, but it may neglected anyway.
When we have no problem then we got 300VA+300VA=600VA
Old 11th May 2006, 04:40 AM   #9
kartino's Avatar
Add: the safest way is connected the DC output, ie, both transformer rectified.
Old 11th May 2006, 05:28 AM   #10
Cloth Ears's Avatar
From the picture in the first post, 40V outputs go to bridge rectifier, 0V to ground.
Any preference in wiring on secondary side (picture on left or right)? Or are both the same?
Thanks for post
Jont.
FS / FTPlitron 30V X 2 @ 300Va jleaman Parts 7 28th May 2012 08:43 PM
Where are all the 300VA 45v toroids at? ShinOBIWAN Solid State 9 15th May 2007 07:52 PM
WTB: 17-19 V 300VA power transformer al2002 Swap Meet 0 14th April 2006 07:58 PM
schematic for a + -30v ,300va smps sagarverma Power Supplies 25 5th January 2006 11:10 AM
Copyright 1999-2017 diyAudio
