Swapping an A/C Adapter - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th May 2006, 01:24 AM   #1
Default Swapping an A/C Adapter
Most of my stomp pedals are daisy chained off of the Boss PSA120T A/C Adapter. Trouble is, I have the Electro Harmonix Small Clone Chorus which uses a different power jack.
What I'd like to do is replace the power jack on the Chorus with a Radio Shack "M" female jack so that the Boss A/C Adapter will plug into it.
I'm not certain if the difference in VDC and/or mA would cause a problem, and if it would, how would I compensate for it?
The Boss A/C Adapter is rated at 9V DC 500mA
The Electro Harmonix A/C Adapter is rated at 9.6V DC 200mA
I popped the hood of the Chorus and there is a resistor connecting from one of the terminals of the power jack lug (ground) directly to the circuit board. Do I need to change the value of the resistor in order to use the Boss A/C Adapter?
If it'll help, here's a link to the schematic:
www.tonepad.com/getFileInfo.asp?id=97
Old 10th May 2006, 07:17 PM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
That circuit is likely to work fine on anything between 7V and 15V.
I use to feel like the small child in The Emperor's New Clothes tale
Old 11th May 2006, 01:16 AM   #3
Thanks Eva.
I need a little help. I wired the coaxial power jack up but didn't get power. This is my first time using a coaxial jack, so I might have the lugs mixed up.
There are 3 lugs - Center Pin, Shell and another that I don't know the name of. Which is which (+, -, ?) ?
Swapping out the microphone in an SPL meter? quickshift Multi-Way 4 5th November 2007 06:17 PM
Swapping components - new Forum??? sharpi31 Everything Else 2 20th July 2007 06:58 AM
Tube Swapping Question Trout Tubes / Valves 15 24th December 2005 09:00 PM
Swapping tda2030b with ???? texus Chip Amps 0 18th March 2005 07:28 AM
Soundcard DAC swapping? Optical Digital Source 2 11th September 2004 05:27 PM
Copyright 1999-2017 diyAudio
