Hey Guys,
Just opened my 2 x 590w into 4Ohms yamaha power amp to discover that the power transformer is only rated for 300VA! I know that manufacturers underrate transformers and depend on the filter reserves for transients, however this seems a bit weak? Which got me thinking that I may be able to use a 180VA toroid to make a light, useful power amp. (300-400w monoblock?) My question is, how close to the full power output of the amp does the power transformer need to be before performance suffers? Is my amp project likely? |
#2 |
Not unless you've figured out how to get more power out of a system than what you put in!
The age-old problem of perpetual motion will have been solved! Steve |
#3 |
There is nothing wrong there. With conventional speaker loads you are likely to burn the voice coils before the transformer has even time to get warm.
Peak to average power ratio of music signals is typically 5 to 20, and speakers are already sized taking advantage of that.
I use to feel like the small child in The Emperor's New Clothes tale |
#4 | |
lol, that's what I thought - very efficient indeed!
Now I have a new project to start
#5 |
Be prepared for some supply voltage sagging (that's what people tries to mitigate with huge transformers). You should consider zeners, current sources and other tricks in order to keep the bias of the amplifier stable with rail fluctuations.
#6 |
Thanks Eva!
#7 | |
Normally a power amp is sized at about VA rating=1.5times output power. By the time you approach VA=Output power Rail sag is already more noticeable, but at this level extra smoothing capacitance can make this accepatable. At VA<0.75times output power, as Eva said, rail modulation starts to approach output modulation in level (well slight exaggeration) so you must ensure the voltage amp stages are not compromised.
regards Andrew T. |
| transformer ratings... pls help | JojoD818 | Solid State | 32 | 23rd July 2010 10:42 AM |
| ratings of output transformer??? | cbutterworth | Tubes / Valves | 6 | 24th January 2008 03:16 PM |
| Little help understanding Transformer ratings | randy5235 | Power Supplies | 12 | 11th December 2006 06:43 PM |
| Transformer ratings??? | AR1 | Power Supplies | 2 | 2nd May 2005 07:02 PM |
| Torroidal Transformer ratings | kestrel200 | Chip Amps | 2 | 8th May 2004 04:59 PM |
| Page generated in 0.08550 seconds (85.96% PHP - 14.04% MySQL) with 10 queries |
