Ultimate shunt regulator
I'm going to build ultimate shunt regulator. I used TL431 so far, but I'd like to build something better. I will use low noise voltage reference source,lowpass filter,error amp and reg transistor. So, what do you think about this topology and do you have any suggestions for error opamp and for reg transistor?
It looks geat:), nice current source, but it's too complicated I think, we can replace transistors error amp with fast opamp, because in my opinion implementation and PCB layout is one of the key to build fast and ultimate regulator,so do you recommend any type of opamp?
