Go Back   Home > Forums > Amplifiers > Power Supplies
Old 21st April 2006, 12:13 PM   #1
redrabbit's Avatar
Question Datasheet psu, 0.1v to 50v @1a...
HERE :
(page 12, Figure 14)
http://www.intersil.com/data/fn/fn817.pdf
...My question is, what would come between this regulator circuit, and the power transformer.......bridge and smoothing caps??
...And what transformer say you?
=RR=
Old 21st April 2006, 01:01 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
You'll need 35-40 VAC, 70-100 VA, 2200-4700 uF in smoothing.
I friend of mine built this PS long time ago and it worked pretty well.
/Per-Anders (my first name) or P-A as my friends call me
Old 22nd April 2006, 03:36 AM   #3
redrabbit's Avatar
Thanks peranders.
...btw, how could this be turned into a dual polarity supply?
...or is that a drasticly different circuit altogether ?
=RR=
Old 22nd April 2006, 07:03 AM   #4
peranders's Avatar
You can built two identical PS and then connect them in series. This will give you a dual suuply.
Old 22nd April 2006, 09:58 AM   #5
redrabbit's Avatar
I'm sorry, I meant a bipolar psu....."plus, minus ( and ground, 0v)" volts output.
=RR=
Old 22nd April 2006, 10:14 PM   #6
peranders's Avatar
I ment that too.
Old 26th April 2006, 02:32 AM   #7
redrabbit's Avatar
OK, so using a center tapped tranny....
positive is one psu,
negative is another,
....and 0v (ground) is shared with both.
Correct?? ( )
=RR=
6G-A4 anyone have a datasheet? jp74 Tubes / Valves 5 23rd June 2009 06:28 AM
Datasheet Piersma Digital Source 3 29th January 2003 08:49 PM
Page generated in 0.08116 seconds (74.65% PHP - 25.35% MySQL) with 10 queries
