Any probs using different PSUs in a computer?
I'll explain more. For my next computer, I plan using an ATX PSU for the motherboard, while the HDDs, optical drives and fans would run off a linear PSU. (With the same ground...) Will it cause any problems? Current flowback? I'm not sure that's what I'll be doing exactly tho. OR Instead of using an ATX PSU, are there not-too-noisy options that are still power-efficient? I never worked with SMPSes, so I'll ask dumb questions. What about a big toroid with switching regulators, and big capacitors to clean the noise? Would it still be efficient?
Antoine http://dmsaudio.ca/ |
#2 |
Considering you will need to deliver 100's of watts? It may take up case real estate. This is interesting but I still think the computer will produce its own noise (is this what you're thinking?).
You would need to consult the ATX specification for this. |
#3 |
I already looked at the specs, but they don't talk about using different transformers.
Anyways... I think I'll just get a good PSU...
#4 |
The specs won't talk about toroids. The specs would be happy if you used a mouse on a treadmill, as long as it gives the required output
Anyway, good luck. |
#5 |
diyAudio Editor
Is there any problem with using two ATX supplies to do this?
I have been considering the same , but both would be ATX supplies that I have. Use the secoond one to power the HDs, the burner and DVD drives, fans, etc. Obviously there might be space issues... |
#6 |
The ATX supply is designed for software turn on. Also on the bench, they sometimes wont turn on unless they detect a load on the 5V rails. Why not use an AT supply (with a real switch) for the drives.
#7 | ||
In fact, I first thought of making 1 big PSU for all the system, but, after I read the specs, I found it isn't as simple as green wire grounded = turn the thing on...
(There are things like overvoltage, overload, overheat protection, a very short delay before power on which isn't nice if you use a big toroid) To power a 2nd ATX from the 1st ATX, all you need is a relay powered from the first to short green wire to ground. Quote:
What I'm really looking for it to eliminate as much noise as possible, since my computer and sound system are right next to each other, and as I'm planning to DIY a case for my next PC, I told myself, why not DIY a PSU also. I thought about a complete linear PSU, but linear regulators aren't really efficient... (And would make a 300W heater) But, what's noisy in SMPSes, the 400Hz transformer, the switching regulator or all these answers? If I take a toroid and switching regulator, I probably put less junk on the power line, but what about RFI / noise / interference? Is the regulator making some itself or can just putting big caps on the power line fix things?
#8 |
Umm... multiple mice on separate treadmills? I feel sure they would be fine as long as you could coordinate turn on.
Noise from the power supply is only one source from a computer. It does not necessarily upset the operation of the computer. Even so, adding your own chokes and caps at the outputs is one way to achieve clean rails. I guess you could also mount your computer far from anything critical, and consider power conditioning (even perhaps to stop noise getting back into the power mains?) |
#9 | |
I'm starting to think about getting a Fortron PSU with (passive) PFC ... Supposed to put less junk on the mains. There's also Active PFC, but on twice-the-price PSUs.
#10 |
It seems someone finally woke up to this with PFC. Maybe it was the power suppliers, or maybe it's just hard to live in this world if you are an appliance that is susceptible to the noise, and your neighbours are noisy.
Just a thought, would anyone consider running the ground connection (that the computer's case is connected to), outside to a dedicated ground stake? |
| Hacking SMPS PSUs? | Spasticteapot | Power Supplies | 4 | 20th November 2006 03:40 PM |
| Can one transformer supply two psus? | xcortes | Chip Amps | 3 | 2nd May 2006 11:52 PM |
| Cascode PSUs | mcai7et2 | Solid State | 3 | 19th February 2004 10:44 AM |
| inductors for PSUs | uli | Pass Labs | 0 | 26th January 2003 07:36 AM |
| Page generated in 0.12828 seconds (79.05% PHP - 20.95% MySQL) with 10 queries |
