I need a schematics for LM317/337 double regulated power supply
Thanks in advance |
#2 |
Have you checked the datasheets from National Semiconductor? They contain plenty of useful application examples.
#3 | |
Yes I have it in hand. I guess I was kinda looking for tips. This is what I have on paper 24,000uf+.1uf--[317]--.1uf+12,000uf___ .33ohm ___ 3300uf+.1uf--[317]--.1uf+1000uf___ .33ohm.___ each 317 has a pot(100uf cap in parallel) at adj pin to ground |
#4 |
With such amounts of capacitance, remember to add diodes to protect the regulators from reverse biasing as the datasheet shows
#5 | |
#6 |
Hi AndrewT
I definitely don’t want to ruin the regulation. I have a power supply in a separate chassis and need to get 40volt down to 18volt and only using 317/337. I will use 3 regulators per rail to get the voltage to 18volts. The 18volt will feed a preamp with 48,000uf per rail. I didn’t think the last .33ohm resistor would be a problem. Should I leave it or remove it? Thanks |
#7 |
Did it Himself
Sorry but that is a very inelegant solution. Why not use a single regulator, or simple emitter follower fed from zener reference?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#8 |
It's quite obvious that he is looking for something exotic while he has little or no knowledge on how to use a LM317/LM337 (two things that usually happen together, as the more electronics you understand, the more you laugh at exotic).
If he just wanted something functional, he would calculate the required capacitances depending on load current and on the maximum allowed input voltage ripple in order to obtain the desired output ripple (and the resulting values would be much smaller than the ones he mentioned). I understand exotic trends quite well, we as humans are very prone to fill the knowledge gap with imagination when we don't have anything better to use. |
#9 |
Did it Himself
I was trying to put it in a less upfront way.
#10 |
Good, you know more about electronics.
richie00boy Here’s the thing. I need to build the power supply with the parts I have but Thanks Eva I don’t need the exotic, just the functional. I planed to do the capacitance calculations but I have the equation on paper somewhere. This is not my only hobby but it is the only one, as much as I love it, which is not going to put money in my pockets, so tend not to keep formulas and equations in my head. Your first post was helpful, thank you. I really don’t know how to take your second. |
| Regulation really needed for SF | mashaffer | Solid State | 2 | 23rd July 2008 09:20 AM |
| Double rail PSU, double ground rail connexion ? | youyoung21147 | Chip Amps | 5 | 6th November 2005 05:12 PM |
| Zen Regulation | hacknet | Pass Labs | 3 | 5th April 2004 08:21 AM |
| How many TDA1541A are needed in parallel to achieve double crown standard ? | Blitz | Digital Source | 39 | 26th January 2004 01:26 PM |
| LC regulation??? | Michel | Solid State | 4 | 30th October 2001 05:42 AM |
