needed 317/337 double regulation
Old 18th April 2006, 01:41 PM   #1
jaudio is offline jaudio
Default needed 317/337 double regulation
I need a schematics for LM317/337 double regulated power supply
Thanks in advance
Old 18th April 2006, 02:16 PM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Have you checked the datasheets from National Semiconductor? They contain plenty of useful application examples.
Old 18th April 2006, 02:42 PM   #3
Yes I have it in hand. I guess I was kinda looking for tips.
This is what I have on paper
24,000uf+.1uf--[317]--.1uf+12,000uf___ .33ohm ___ 3300uf+.1uf--[317]--.1uf+1000uf___ .33ohm.___
each 317 has a pot(100uf cap in parallel) at adj pin to ground
Old 18th April 2006, 03:00 PM   #4
Eva's Avatar
With such amounts of capacitance, remember to add diodes to protect the regulators from reverse biasing as the datasheet shows
Old 19th April 2006, 08:53 AM   #5
That last 0.33ohm is going to ruin your regulation. Is that what you need?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th April 2006, 09:36 AM   #6
Hi AndrewT
I definitely donít want to ruin the regulation.
I have a power supply in a separate chassis and need to get 40volt down to 18volt and only using 317/337. I will use 3 regulators per rail to get the voltage to 18volts. The 18volt will feed a preamp with 48,000uf per rail. I didnít think the last .33ohm resistor would be a problem. Should I leave it or remove it?
Old 19th April 2006, 09:46 AM   #7
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Sorry but that is a very inelegant solution. Why not use a single regulator, or simple emitter follower fed from zener reference?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 19th April 2006, 09:58 AM   #8
Eva's Avatar
It's quite obvious that he is looking for something exotic while he has little or no knowledge on how to use a LM317/LM337 (two things that usually happen together, as the more electronics you understand, the more you laugh at exotic).
If he just wanted something functional, he would calculate the required capacitances depending on load current and on the maximum allowed input voltage ripple in order to obtain the desired output ripple (and the resulting values would be much smaller than the ones he mentioned).
I understand exotic trends quite well, we as humans are very prone to fill the knowledge gap with imagination when we don't have anything better to use.
Old 19th April 2006, 10:47 AM   #9
Did it Himself
I was trying to put it in a less upfront way.
Old 19th April 2006, 11:35 AM   #10
Good, you know more about electronics.
richie00boy
Hereís the thing. I need to build the power supply with the parts I have but Thanks
Eva
I donít need the exotic, just the functional. I planed to do the capacitance calculations but I have the equation on paper somewhere. This is not my only hobby but it is the only one, as much as I love it, which is not going to put money in my pockets, so tend not to keep formulas and equations in my head.
Your first post was helpful, thank you. I really donít know how to take your second.
needed 317/337 double regulationHide this!Advertise here!
Regulation really needed for SF mashaffer Solid State 2 23rd July 2008 09:20 AM
Double rail PSU, double ground rail connexion ? youyoung21147 Chip Amps 5 6th November 2005 05:12 PM
Zen Regulation hacknet Pass Labs 3 5th April 2004 08:21 AM
How many TDA1541A are needed in parallel to achieve double crown standard ? Blitz Digital Source 39 26th January 2004 01:26 PM
LC regulation??? Michel Solid State 4 30th October 2001 05:42 AM
Copyright ©1999-2017 diyAudio
