#11 |
leakage on both electros are a problem. You only have 1.1mA flowing through your current source. This gives about 56mW on each Zener. It's better to bias them with 10% (or more) of rated capacity (about 100mW). Then allow for leakage in the caps and add these together to find the Current Source requirement. You've got a little capacitance multiplier in there. While the input voltage varies from your set point the FET is dissipating all the spare energy. Particularly at start up. As Eva & Xpro said:- lower your time constant.
regards Andrew T. |
#12 |
Hi Alex and Andrew, thanks for the replies.
Unfortunately, you're talking to a newbie here who only uses Duncan PSUD to make PSU The protection diode's direction is positive to the gate? I will change to 100K and 10uF to change the time constant. |
#13 |
once you have the modification done, go and measure the volts drop across the 100k. It will give you the leakage. I then suggest you consider reducing the 560r slightly to increase the Zener current, about 270r to 330r should be about right. This will raise your output voltage very slightly, but more importantly will allow small variations in leakage current to have less effect on the Zener voltage due to it's being biased more heavily.
regards Andrew T. |
#14 | |
Cheers Alex |
#15 |
Hi Andrew,
changed to 100K and 10uF, I get 2.4V across 100K. changed 560R to 280R (560R ||) and got 2.2V across 100K, with a slightly higher voltage- 218.3V vs 212.4V does that look right? Hi Alex, thank you for the updated schematic. I'll give it a try. I've seen a schematic with the zener on the mosfet the way you described it, but for a power amp (I think Rod Elliot's site). Is the protection scheme the same? Most schematic (series pass) do not have that, but rather have an inverted 1N4007 between Drain and Source, but I suppose the IRF840 already have that internally. |
#16 |
The zener between the gate and source is to protect the gate from being zap by a high voltage that will break down the insulation.
P.S the IRF840's maximum gate voltage is +/-20V so you need to put a lower voltage zener in to protect it. |
#17 |
hi ifrythings, geez i saw that in the spec sheet
now that make me wonder, why couple of high voltage designs i saw on the net does not actually include that protection |
#18 |
They leave it out to save a few pennies
#19 | ||
these numbers look OK. Quote:
I am slightly perplexed by the lower leakage through the 100k Quote:
regards Andrew T. |
#20 |
ifrythings, geez at the expense of the MOSFET
Thanks Andrew, will make change and report back. |
| Dropping rectifier filament voltage | Nightpuma | Tubes / Valves | 13 | 2nd February 2009 10:55 AM |
| Location of voltage-dropping power resistor | hollowman | Power Supplies | 21 | 5th December 2008 08:13 PM |
| dropping heater voltage | jarthel | Tubes / Valves | 17 | 21st September 2006 04:50 AM |
| MOSFET gate voltage | xplod1236 | Parts | 17 | 4th December 2004 03:23 PM |
| Page generated in 0.11994 seconds (72.05% PHP - 27.95% MySQL) with 11 queries |
