Help w/ Eagle PSU board... - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 3rd April 2006, 10:24 PM   #1
sklimek is offline sklimek  United States
sklimek's Avatar
Default Help w/ Eagle PSU board...
I am building a separate PSU board for Rob’s ‘Maxhawk’ OPA629/BUF634 headphone amp found here –
http://maxhawk.bravepages.com/projects/Headphone/
The amplifier has an on board 15V regulated power supply but he mentioned that “although I couldn't hear it, was 120 Hz components on the power supply. Once you pass through the on-board regulators, most of the line frequency harmonics were gone, but I could still see it on a scope.
If I were to build my power supply again, I'd probably use a large inductor and cap to try to kill the 60 Hz harmonics, or perhaps pre-regulate the power supply to 15 volts”.
This PSU board (a choke and cap combo) is my first project designing w/ Eagle and I wouldn’t mind a few suggestions as to the errors I have not detected. Also, I need help in selecting what value choke for this board. Does anyone know a good link that illustrates pad sizes for the different components, I chose them randomly. Lastly the transformer specified here ‘before’ this custom PSU board I designed is a 15V .666 amp/10VA. I figure an 18V/15VA step-up would probably be good here??
Here is the schematic -
Stan
Old 3rd April 2006, 10:26 PM   #2
sklimek's Avatar
Default Help with Eagle PSU board...
And here is the board...
Thanx!
Sure Electronics New Tripath Board 4*100W class-D Amplifier Board 7788q Class D 353 22nd February 2017 06:29 PM
Board to board soldering: BGA/SMD style NeoY2k Parts 0 7th December 2008 05:36 PM
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 0 15th May 2008 02:36 AM
Eagle PCB question about board border rtarbell Everything Else 3 23rd March 2007 01:33 AM
lm3886 linkwitz board + ?'s on Eagle srfranci Chip Amps 5 16th February 2006 01:22 AM
Copyright ©1999-2017 diyAudio
