Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th April 2006, 04:12 AM   #11
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I don't remember thoriated stating mains rated insulation as a requirement. Obviously, toroids are best suited for applications where such insulation is not required. If he requires such insulation, he may have to consider also E or ETD cores with layers of bifilar primaries interleaved with secondaries.
Implementing primary peak or average current control is another alternative that allows to use somewhar asymmetric primaries.
BTW: Tell us if you find any suitable supply of triple insulated wire.
Old 6th April 2006, 02:13 AM   #12
Thanks much for the responses. The input voltage range will be 16-40VDC, as I understand it. The need for isolation is not definitively established, but probably a good idea for the intended application. The multiple toroid approach Eva suggested is probably the most practical, although I am also interested in trying the planar approach.
The application would be as a brushless DC motor supply. (Another portion of the project would deal with actually controlling the motor.) I have designed a number of switching power supplies of various sorts, but nothing at nearly this high a power rating to date.
toroid for car amp smps sss Car Audio 251 11th January 2009 02:55 PM
Toroid or EE Ferrite core, which is Best for 240V mains SMPS Workhorse Power Supplies 49 6th February 2007 06:44 PM
toroid transformer mounting question thoriated Solid State 3 12th January 2004 04:45 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.07104 seconds (66.91% PHP - 33.09% MySQL) with 10 queries
