ifrythings said:The circuit will help with the inrush of current but why not just use a NTC?
Because it haven't got time to getting colder when you reswitch the amp fast (or in case of a short blackout), and the toroidal transformer will kick the fuse because of the inrush current. Some manufacturers using NTC for this purpouse, but it's a slightly incorrect solution.
Best regards,
peranders said:By this you mean
If you don't have any problems with the inrush current, then you don't have a problem.
Well right now i dont have a relay in there and i have a big issue with inrush. Lights dim and even my UPS beeps.
You could try this one:http://www.diyaudio.com/forums/showthread.php?s=&threadid=6654&highlight=speaker+protection
- Power Supplies
- Limiting Inrush??
