Linear Supply Help
Linear Supply Help
Old 27th March 2006, 06:00 PM   #1
Deltat is offline Deltat  United States
Send a message via AIM to Deltat Send a message via MSN to Deltat Send a message via Yahoo to Deltat
Default Linear Supply Help
I have a couple questions about designing a good linear power supply for class T based subwoofer amp. Im using a TK2350 eval board and i would like to be able to output about 500W. I have a 625VA toriodal xformer with 2 35V secondaries. Im having a couple problems. How can i control inrush current? When i turn this guy on lights dim, and in my office my UPS will even beep. I realize at the instant its turned on those caps appear as a dead short(ideally). Also it seems to be noisy, jsut having a signal from a function generator tied directly to an o-scope you can see it get pretty nasty when my powersupply is on. Lastly, how do i correctly give the supply a discharge path when off?
I have attached my schematic below of what im thinking of redesigning too, the only real difference is the .1uF and fuses before the rectifier as well as the relays at the output(hoping the delay will remove any turn on pop in the amp.
Kurt
Old 27th March 2006, 07:10 PM   #2
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Linear Supply Help
Here are two good threads.
http://www.diyaudio.com/forums/showt...022&highlight=
http://www.diyaudio.com/forums/showt...778&highlight=
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 55 pcb's in order. 49 paid.
Linear Supply HelpHide this!Advertise here!
linear pc power supply? cowanrg Power Supplies 45 20th July 2012 02:49 PM
Can you run a computer on a linear power supply? JZatopa Digital Line Level 11 17th June 2009 06:29 PM
Regulated Linear 5V ~1A supply percy Parts 4 22nd April 2009 09:00 AM
Which capacitors to use (linear supply) Jason Hubbard Power Supplies 4 29th December 2006 01:51 PM
60 V 5A linear power supply duffman Solid State 2 29th October 2005 07:20 AM
