Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th March 2006, 02:34 AM   #61
N-Channel's Avatar
Send a message via AIM to N-Channel
That's not a bad idea. Especially, since I have enough to make roughly 5kW worth of a 60Hz stage of a 120/240V AC Inverter
Old 29th March 2006, 03:34 AM   #62
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Old 29th March 2006, 08:00 AM   #63
subwo1 is offline subwo1  United States
subwo1's Avatar
Sounds like you're set to go, Steve.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 29th March 2006, 02:47 PM   #64
N-Channel's Avatar
Sure, now alls I need is a good control circuit, assorted support components, big Ls and Cs (I want sinewave out with reasonably high efficiency), and a good case to put it in.
I was thinkin' of PWM'ing the output stage at something like 30-36kHz, while modulating that at 120Hz, then some big Ls & Cs to recover the 60Hz component. Obviously, for a power level of 5-10kW, I would need some very big components. Not wanting to get too far off-thread, this may have relevance with Alex's original questions.
Old 29th March 2006, 03:52 PM   #65
subwo1's Avatar
Indeed, getting decent efficiency at high power can become less fun, especially because of increases in size and parts cost.
USMPS
Old 4th October 2012, 05:28 AM   #66
I AM SUFFERING WITH THE SAME PROBLEM THAT IS PERSISTING WITH ALEX IN THIS POST.
I HAVE USED TWO SWITCH FORWARD CONVERTER
RATING IS 24V AND 14A.
WITH A MERE 20 OHM LOAD THE VOLTAGES ARE FLUCTUATING.
ML4800 PWM+PFC IC HAS BEEN AS CONTROLLER
Old 4th October 2012, 05:35 AM   #67
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Welcome to the forums. Please don't use full text capital letters again when posting. There is a ''rules'' section to read in the top page menu to be generally informed too.
half bridge SMPS secondary voltage drop problem ? alexclaire Power Supplies 6 10th November 2006 03:19 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
