Half bridge smps voltage drop problem
Old 28th March 2006, 05:12 PM   #51
subwo1 is offline subwo1  United States
subwo1's Avatar
Kanwar,
I like the IR22110 in the circuit. I have yet to try some IGBT's. I like how MOSFETs have body diodes since it saves having to add in external freewheeling diodes.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 28th March 2006, 05:27 PM   #52
subwo1's Avatar
Default Re: Re: Re: Re: MOSFET driver buffer
Originally posted by mzzj
In case link outdates, try searching "an70" and look for "A Monolithic Switching Regulator with 100mV Output Noise"
http://www.linear.com/pc/downloadDoc...30,P1535,D4159
Starting somewhere page n. 55 is small EMI-probe. Small size makes it possible to track down even invidual high-dI/dt traces on board, crappy recovery behaviour etc.
I am glad it finally came through since PDF causes my computer trouble under even good circumstances. The document has some really useful information in it. I think I will find it interesting to simulate the LT1533 in LTspice. Gotta start working on one of those probes.
Btw toroidal transformer construction shown on page 52...what a hell they were thinking?
It doesn't look like the lowest leakage inductance was the objective.
USMPS
Old 28th March 2006, 05:30 PM   #53
Workhorse is offline Workhorse
Workhorse's Avatar
Originally posted by subwo1
Kanwar,
Hi Subwo1,
Yes you are right buddy, but IGBT offers a low cost solution and freewheeling diodes are then to be connected externally for fast reverse recovery...IR2110 serve as simple and effective approach as well...
Old 28th March 2006, 06:40 PM   #54
subwo1's Avatar
Originally posted by Workhorse
Hi Subwo1,
Thanks for those thoughts, Kanwar. I plan to investigate the prospect of using some IGBTs, especially in ZVS circuits, along with IR2110 drivers.
USMPS
Old 29th March 2006, 02:52 AM   #55
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Default Stone-Age
Eva, Sobwo1 and mzzj,
You three are making me feel as if I'm stuck in the stoneage with my rails of old Motorola MTW20N50Es (1998 date codes) with their 0.24W Rds(on). I had planned on using some of them in my revived half-bridge SMPS. When I get the time, and $$, I will order some really good IGBTs, perhaps from IR. But I will stick with my batch of old 1990 date coded IR2110s.
Steve
Old 29th March 2006, 02:59 AM   #56
mzzj is offline mzzj  Finland
Default Re: Stone-Age
Steve
Those MTW's didnt look bad at all compared to IRFP450.
Old 29th March 2006, 03:04 AM   #57
N-Channel's Avatar
Default MTW vs. IRFP
Yeah, I looked at the spec sheets for both, the IRFP450 is equivalent to the MTW14N50, and the MTW20N50E is equivalent to the IRFP460.....
Old 29th March 2006, 03:13 AM   #58
Default Re: MTW vs. IRFP
Equivalent in rds-on but IRFP460 has 3 times bigger Crss making it #!"% useless in bridges. I would exchange my stock of IRFP450's any day to MTW's
Old 29th March 2006, 03:26 AM   #59
N-Channel's Avatar
I meant in the Vdss and Id ratings. I wasn't looking at the C(iss) or C(rss), but now that you mention it, that's a boatload. I almost bought a rail of the '460s from eBay. Glad I passed.
Old 29th March 2006, 03:29 AM   #60
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Go on, MTW20N50E are somewhat better than my old IRFP460 (probably from early 1990s), MTWs have three times lower reverse transfer capacitance and lower Rds-on. Also, currently I only have 4 of these devices, but if I had rails full of them I would consider using them as a challenge. You can paralell banks of two or three and use high current buffers to drive the gates (see ZTX851 and ZTX951, I was using these as emitter followers driven from a CD4050 with all 6 gates paralelled).
Half bridge smps voltage drop problemHide this!Advertise here!
half bridge SMPS secondary voltage drop problem ? alexclaire Power Supplies 6 10th November 2006 04:19 PM
