switch-mode sine wave inverter design
Old 21st March 2006, 02:47 AM   #11
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
BCA solves the body diode problem and reduces output ripple at low voltages, but it requires four inductors rated at the full maximum peak output current for a full bridge.
SiC diodes solve the reverse recovery problem at the expense of showing conduction losses similar to the ones that you would obtain by paralelling 60V schottkys until the required voltage rating is achieved (and they are not particulatly cheap).
Also, isn't BCA patented by Crown and not freely useable in commercial products for the next 15 years or so?
Damn!!!
Old 21st March 2006, 09:37 AM   #12
mzzj is offline mzzj  Finland
Damn!!!
There is no such a thing as free lunch
10pcs of shottkys? Sic is not that bad.
Note that SiC-diodes are not that bad compared to ordinary ultrafast devices, for example MUR1560 has forward voltage drop of 1.5v vs Cree CSD20060D 1.8v
At higher temperatures things dont look so nice as its something like 1.2v for mur and 2.4v! for SiC. But you dont want to run your Si-diodes at Tj=175c anyways because reverse recovery charge multiplies by quadrillion.
Yeah, not for commercial desings Problems with Teetee's inverter?
Speaking of shottkys, use of low voltage shottky and ultrafast recovery diode to bybass mosfet body diode might be one option at these voltage levels.
Old 21st March 2006, 09:42 AM   #13
pinkmouse is online now pinkmouse  Europe
pinkmouse's Avatar
Guys!
Bear in mind the original poster. I think Helen might want something a little more practical in the way of help. Abstract component discussions are fine, but not entirely relevant here!
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
switch-mode sine wave inverter designHide this!Advertise here!
Sine Wave Generator with bulbs (Sine-lightenment) Rodeodave Everything Else 6 21st July 2008 12:19 PM
modified sine wave power inverter saltmiser Power Supplies 3 23rd April 2008 05:55 AM
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
