Will 7915 Regulator Handle - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th March 2006, 03:33 PM   #11
testlab is offline testlab  United States
testlab's Avatar
Watch the pinout on these guys! Sometimes they are not the same as the National part. You probably have a pinout error.
It's not whether you win or lose, it's how you lay the blame.
Old 20th March 2006, 03:46 PM   #12
The pin outs were the same, but the device didn't begin to regulate until the load was drawing about 3ma.
Old 28th March 2006, 06:35 AM   #13
clem_o is offline clem_o  Philippines
Originally posted by LHMAudio
I read through the ST Micro data sheet a number of times looking for an indication of the minimum required current draw and didn't see anything.
Hi, see encircled portion, from the ST datasheet for the 7915AC (p5)... 5mA is the minimum load. Load Regulation spec says the same thing... Hope this helps...
Cheers
Old 28th March 2006, 07:02 AM   #14
Default 7915 regulator
The maximum input voltage for this chip is -30V, so it is entitled to misbehave. The fact that it seems to work for a brief period while the main reservoir caps discharge is compatible with this interpretation. Try connecting a large zener diode, capable of carrying enough current in series with the inoput to the regulator, and also add small (0.1u) caps to input and output, as already suggested.
Andy G4OEP
Old 28th March 2006, 03:47 PM   #15
The specific regulator I used was the ST Microelectronics L7915ACV which has a maximum input voltage of -35VDC. The data sheet can be found here:
http://www.st.com/stonline/books/pdf/docs/2150.pdf
Thanks for the info on how to find the minimum current required for regulation. I have completed the circuit and it has been working correctly.
Thanks to everyone for you help. I love this forum.
Lindsay
7815/7915 dual supply hum problem Lenn Art Power Supplies 8 22nd March 2011 09:57 PM
Pin compatible 7815/7915 replacements? i-s Parts 9 26th October 2010 04:05 PM
Can the 338 regulator handle 4 Ohms? amo Chip Amps 42 13th October 2007 04:17 AM
Exploding 7915 diarav Power Supplies 6 11th June 2007 12:21 PM
Can we handle more zen? bertjan Pass Labs 10 31st July 2006 10:04 AM
Copyright ©1999-2017 diyAudio
