#11 |
Hi Eva,
thank you.
regards Andrew T. |
#12 |
Eva:
..Thus, when measuring from the primary with the secondary shorted, you have to substract the primary DC resistance plus 13.6 ohms from the primary measured impedance in order to get the actual inductive reactance.... and donīt forget to subtract it geometrically, otherwise : ...error will ruin your experiment.. Regards Heinz! |
#13 |
Percy or anyone who can respond,
When u measured the primary impedance, 350ohm, is that just the primary inductor's impedance or does it include the DC resistance as well (Zinductor + Rdc)? also, I take it that there is no impedance reflection from the secondary since the secondary is a open circuit. Primary:- Open Secondary = 350ohm (.93H) thnx |
#14 |
Thus, when measuring from the primary with the secondary shorted, you have to substract the primary DC resistance plus 13.6 ohms from the primary measured impedance in order to get the actual inductive reactance." More correct would be: X = sqrt(Z^2 - R^2) Where X is reactance, Z impedance and R resistance. For example a 10 ohm resistor in series with a capacitor having 10 ohms of reactance at the specific frequency will have an impedance of 14 ohms. |
#15 |
Maybe I should have made the question more clearer.
When u measure the primary impedance with the secondary OPENED, are u actually measuring the primary INDUCTOR'S impedance or are u measuring (Zprimary_inductor+Rdc), assuming the that there is no reflecting impedance from the secondary since the secondary is a open circuit? megajocke, When u shorted the secondary, don't forget to account for the reflecting impedance from the secondary seen by the primary. thnx |
#16 |
Here's a Word doc that should be of use. Whenever I find some handy formula, I toss it in. The first section on transformers should be pretty clear.
I used to be an audiophool like you but then I took an arrow to the knee. |
#17 |
Of course, when measuring with the other winding shorted you will see the own resistance, the leakage inductance and the reflected resistance of the other winding all in series.
But my point is that the magnitude of the impedance does not equal the sum of the magnitudes of reactance and resistance. Z = R + X is true though if you do the calculations with complex numbers [X = jwL where j = sqrt(-1) and w = 2*pi*f] With the other winding open the winding resistance will be neglible compared to the inductive reactance of the magnetizing inductance though. |
#18 |
Thanks u, megajocke and Hoffman, for your help. Hoffman, ur doc certainly helps alot.... thnx |
| How to measure inductance in the x-over. | marchel | Multi-Way | 3 | 12th December 2007 11:23 AM |
| Who might be able to measure inductance? | fazman | Multi-Way | 8 | 21st August 2006 12:26 PM |
| measure inductance | henryp | Parts | 2 | 5th July 2006 10:44 PM |
| Designing transformer leakage inductance | DaBit | Power Supplies | 3 | 17th January 2006 08:08 PM |
| How to measure inductance? | Jimmy154 | Multi-Way | 41 | 20th July 2003 03:37 AM |
| Page generated in 0.09842 seconds (77.38% PHP - 22.62% MySQL) with 11 queries |
