Weird (?) problem with 317 regulator
Old 8th March 2006, 10:46 PM   #1
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Default Weird (?) problem with 317 regulator
I have some simple lm317 regulator circuits, like in the datasheets with added Cadj. While playing around with a more or less antique scope I saw that one circuit does not correct low frequency shifts between say 0.5 - 4 Hz (A 'jumping' y-axis). This with input at x10, 0.02V/div at diverse time/div settings. It is also a bit noisier. The other boards correct the shifting before the regs. Pluggin in a new 317 changed nothing, and I can't find a defective part. What is it, and what shall I look for?
Rüdiger
Old 3rd April 2006, 05:18 PM   #2
Onvinyl's Avatar
... the input cap is about 1,5 inches away, placing an additional 0.1uF Cap close to the pin solved it.
Rüdiger
Weird (?) problem with 317 regulatorHide this!Advertise here!
weird problem sberube Solid State 15 22nd October 2008 06:27 PM
weird hum problem audiopro Tubes / Valves 4 31st August 2008 08:16 AM
NAD 306 weird problem Juko Solid State 1 4th May 2007 08:21 AM
Weird Amp Problem Stewart8989 Car Audio 3 6th April 2007 06:54 AM
Weird PSU problem phn Power Supplies 8 6th February 2007 02:42 AM
Copyright ©1999-2017 diyAudio
