Best diodes for generic power supply
Old 9th March 2006, 10:38 AM   #11
gmphadte is offline gmphadte  India
http://www.ieechina.com/Upload/Tech/...1404290625.pdf
Old 9th March 2006, 11:27 AM   #12
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Originally posted by Upupa Epops
Sound of diodes....Jesuschrist !....
Some people claim to notice a difference. That aside, there are also EMC/RFI issues to take into account.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 9th March 2006, 11:59 AM   #13
Upupa Epops is offline Upupa Epops  Czech Republic
It is confusing of reason and result - low PSRR, amp on border of stability, wrong design of PCB, sensitivity for HF disturbing at input etc... Isn't problem to get with normal diodes SNR over 120-125 dB, with any special low noise devices ( at line levels... ), if all is correct designed ....
Old 9th March 2006, 12:28 PM   #14
jotape is offline jotape  Europe
We should always think in the audio systems as a WHOLE.
Old 9th March 2006, 12:38 PM   #15
lndm is offline lndm  Australia
Diode commutation noise is not like common thermal/resistance noise which is usually relatively quiet and resembles white noise.
Diode noise is short spikes that on their own are largely inaudible, but they are very high in level. It takes this wideband high voltage spike to ring the power supply.
Old 9th March 2006, 10:19 PM   #16
powerbecker is offline powerbecker  Germany
Hello,
there is no current recovery problem, but in some cases hf-generation can occur if one uses diodes with higher capacities together with a transformer with some leakage inductance.
In this case there is one (not four!) small snubber the problem solver!
The "funny" thing is that usually schottkey´s have bigger capacities!
You can start read about from here:
http://www.diyaudio.com/forums/showt...=&pagenumber=5
Heinz!
Old 10th March 2006, 03:19 AM   #17
pwillard is offline pwillard  United States
I'm sure I read somewhere that people were using Switching Mode Power Supplies and Microcontrollers in their Hi-Fi designs... all of which, in my mind, do WAYYY more to induce HF noise than a Power Diode like a 1N4004 could ever hope to do.
I realize that a lot of designs, especially Gainclones, like to use those really cool looking fast diodes in TO-220 cases... but WELL FILTERED DC power (both HF and RIPPLE filtered) would seem to be able to completely overcome anything a "standard" diode could do while changing state.
I'd be more worried about what a local FM radio tower could induce into my amp than what the diode might do...
So... I guess I remain unconvinced it makes a difference... still haven't lab tested though.
pw
Old 10th March 2006, 06:28 AM   #18
Not me...
Yes, but the trouble is getting there. Filtering requires resonant circuits, and whilst we try to have them behave themselves and to act at infrasonic frequencies, there are always parasitics.
Electrolytics in particular usually have an inductive component due to their plates being rolled, that when combined with their capacitance, resonates in the upper midrange.
Old 10th March 2006, 07:08 AM   #19
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
When you mention "very high in level" you must put this into perspective, compared to what? Bear in mind that 99.99% of all high-end gear have regular diodes.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 25 pcb's in interest.
Old 10th March 2006, 07:40 AM   #20
No I don't. I understand the problem conceptually as I'm sure you do too. I'm explaining it conceptually. I build according to guidelines, common sense, and my training. If it's broken I fix it and I enjoy much success. Therefore I speak from experience.
Not interested in specifics here.
http://www.passlabs.com/downloads/ar...owersupply.pdf
Best diodes for generic power supplyHide this!Advertise here!
SS Power Supply and generic opamp PCB. Geek Swap Meet 16 31st January 2009 10:01 AM
Sony Xa7-ES cdp power supply diodes Chilli6565 Power Supplies 2 20th April 2008 09:59 AM
Sony Xa7-ES cdp power supply diodes Chilli6565 Power Supplies 0 20th April 2008 04:52 AM
ID ProArt 100 power supply diodes Ampdoc Car Audio 1 10th August 2007 09:47 AM
power supply diodes voltage rating? Dominique Parts 6 27th April 2005 03:45 PM
