#71 | |
John,
Ciao, George |
#72 | |
It is also helpful to know the winding coupling capacitance, and DC Resistance of the primary and secondary -- you can also measure this with a bridge. There are a number of papers on calculation of snubber values -- and different types of snubbers for the application -- one often cited paper is by Hagerman "Optimum Snubbers" -- easy to find on the web. |
#73 |
Hi Jackinnj,
thanks for that link. I have Hagerman saved.
regards Andrew T. |
#74 |
Jackinnj,
should the primary or the secondary be shorted ? Not arguing, just thought I had heard/read otherwise somewhere so I thought I'd confirm. I used Speaker Workshop to measure the inductance. |
#75 |
Banned
#76 |
Elso,
It's good that You have reported that thread here, thanks! Though if You intended to say "we are going in circles; everthing had been told before" then I say yes, we are going in circles -- though just the post 8 of that thread [by SY] justifies the new efforts here.. Ciao, George |
#77 | |
....and it seems you've taken up smoking !
http://sites.google.com/site/quasisdiyaudiosite/ |
#78 | |
The links in the first post are nice. It's good to see that what I recall from previous work experience is still consistent with what they write. It is bad to see that they have not advanced a bit in TRR testing over the last 20 years. Gensemi link was dead, though. Any manu's actually write about using fast diodes in line supplies, or are all the manu tech papers out there still all about switching stuff and transient V-I losses (losses during switching)? Cheers, John |
#79 |
sorry for bringing up this old thread. Does anybody have suggestions for fast switching, smooth recovery diodes to replace 1N4007s in a preamp? (and a source for them) These "Hexfred" diodes are quite interesting: HFA15TB60PBF pdf, HFA15TB60PBF description, HFA15TB60PBF datasheets, HFA15TB60PBF view ::: ALLDATASHEET ::: ... albeit they are guite large and expensive and I would like to find a diode with comparable specs (max forward current does not need to exceed 1A) but with smaller size, maybe regular "axial" kind of diode since 1N4007s are too. Regards, Legis Last edited by Legis; 12th August 2011 at 02:13 PM. |
#80 |
Hi guys, Vector plane makes a good point, in all the stuff I work on, audio gear and test gear, all the power supplies use...1N400x. That said, HexFred's or Schottky's is way more sexy then a plain ole diode. For a few bucks, who cares, I'll use the over engineered fancy devices and enjoy the result weather or nor I can hear it...or even measure it. Its a fun...hobby. Thanks all.
| SS Power Supply and generic opamp PCB. | Geek | Swap Meet | 16 | 31st January 2009 09:01 AM |
| Sony Xa7-ES cdp power supply diodes | Chilli6565 | Power Supplies | 2 | 20th April 2008 08:59 AM |
| Sony Xa7-ES cdp power supply diodes | Chilli6565 | Power Supplies | 0 | 20th April 2008 03:52 AM |
| ID ProArt 100 power supply diodes | Ampdoc | Car Audio | 1 | 10th August 2007 08:47 AM |
| power supply diodes voltage rating? | Dominique | Parts | 6 | 27th April 2005 02:45 PM |
| Page generated in 0.11649 seconds (82.82% PHP - 17.18% MySQL) with 11 queries |
