Modifying Jung Regulator For 5V Output
Old 3rd March 2006, 03:13 PM   #1
bryman79 is offline bryman79  United States
bryman79's Avatar
Default Modifying Jung Regulator For 5V Output
Hello All,
I currently have a Jung Regulator PCB made by AOS. Is it possible to modify it to output 5V without significantly altering the board? In the schematic (here: http://www.aoselectronics.com/gfx/jsr/jung_pos.gif), you can see that the reference voltage is 6.9V, so that clearly would have to be dropped below 5V for a 5V output. Any ideas?
Thanks,
Bryan
Old 3rd March 2006, 03:15 PM   #2
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb Re: Modifying Jung Regulator For 5V Output
Originally posted by bryman79
Hello All,
Thanks,
Bryan
Other reference?
Old 3rd March 2006, 03:37 PM   #3
bryman79's Avatar
Any hints on a substitute reference that would equal the LM329 in performance? I see that some use the TL431... has anyone measured the noise at the output vs. the LM329?
Thanks,
Bryan
Old 3rd March 2006, 04:18 PM   #4
GaryB is offline GaryB  United States
Bryan,
Try an LM385-2.5v. Its a good quality reference thats available in voltage ranges appropriate for a 5v regulator.
---Gary
Old 4th March 2006, 07:20 AM   #5
bryman79's Avatar
Gary,
Will substituting the LM385 require any other part changes (e.g., the 4.99k resistor)?
Thanks,
Bryan
Old 12th March 2006, 03:05 PM   #6
bryman79's Avatar
I've since run across ALW's pdf article that suggests using the LM336Z-2.5 and the AD817. I've emailed him, but no response. As such, I have two questions:
1. Why the change from AD825 to AD817? I've heard that both will operate at voltages below 5V...
2. Anyone have experience (listening or measuring) with the LM336Z-2.5 vs. the LM385-2.5?
Thanks,
Bryan
Old 12th March 2006, 04:08 PM   #7
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
I have tested with AD825 at 5 volts, even down to 3.1 volt and this is under the specs but it worked.
As reference a LM431 will work and surely many other references at 2.5 volts.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 65 pcb's in order. 59 paid.
Old 12th March 2006, 04:18 PM   #8
moamps is offline moamps  Croatia
http://www.diyaudio.com/forums/showt...=&pagenumber=1
Old 2nd April 2006, 06:18 AM   #9
bryman79's Avatar
Old 2nd April 2006, 08:57 AM   #10
Banned
Lightbulb 5 V reference
You can use a 5V reference with a gain of 1 amplifier. In other words the regulator must have unity gain then.
LT1021-5, MAX6250, AD586, REF02.
Modifying Jung Regulator For 5V OutputHide this!Advertise here!
yes, another jung regulator, i know geekysuavo Power Supplies 8 25th September 2009 12:29 PM
WTB: Jung Super Regulator PCB's vadimgal Swap Meet 4 29th May 2005 06:04 PM
