PSU for my Leach AMP
Old 22nd February 2006, 04:23 PM   #1
JensRasmussen is offline JensRasmussen  Denmark
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Default PSU for my Leach AMP
Hi all,
I have been working on a PSU for my Leach amps.
Please comment on the schematics
Thanks for any input
\Jens
Old 22nd February 2006, 04:46 PM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Which software do you employ to do these schematics?
Old 23rd February 2006, 06:43 AM   #3
Eva,
I have an Adobe writer on my work laptop, but try looking up cutepdf.
I lets you generate PDFs from any windows program
Any comments on the schematics?
\Jens
Old 23rd February 2006, 12:00 PM   #4
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Jens,
would MUR810 be sufficient ?
You are planning a PS board layout ?
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 23rd February 2006, 12:08 PM   #5
I will go for the MUR1560 type (15A 600V)
Yes I'm planning the PCB right now
\Jens
Old 23rd February 2006, 01:08 PM   #6
R.I.P.
Hi Jens,
how about leaving a resistor gap on each cap (C1, 2, 10, 11 etc) to allow RC snubbers across the rectifiers. Either link across or add R to suit.
I would raise the value of the cap discharge resistors. 10k to 20k would suffice.
I am not a believer of fuse in the supply to the rectifier. Provide a mains primary fuse and optionally secondary fuses after the smoothing caps.
A fuse before the caps has to survive a very big charging pulse and would need to be T rated as well as large value (I'm not sure your proposed T5A will survive). Then fuses in this early location are of little protection value when serious faults develop down stream.
Try adding a 100n across the bridge + to - and ~ to ~ but at the rectifier location to give best attenuation of high frequency spikes before track inductance reduces their effect.
regards Andrew T.
Old 23rd February 2006, 07:16 PM   #7
Andrew,
Thanks I removed the fuses, see I you like the layout
Schematics first
\Jens
Old 23rd February 2006, 07:17 PM   #8
Bottom
Old 23rd February 2006, 07:19 PM   #9
Top
Old 23rd February 2006, 07:57 PM   #10
Eva's Avatar
The capacitor that (by experimentation with real components) I have found to be optimum in order to supress the sharp turn-off spike of conventional diode bridges, without causing more ringing than it supresses, is just a single 22nF across both AC terminals of each bridge (as close as possible). No more capacitors are required, altough a RC network in paralell with that 22nF capacitor may help to damp transformer winding resonance (values here are highly transformer-dependent, the range for big EIs is probably 100nF and 47ohm).
MUR diodes are probably going to require smaller capacitances because the recovery times are an order of magnitude lower.
EDIT: Have you considered placing +Vcc and -Vss outputs near the ground output to reduce wiring inductance?
PSU for my Leach AMPHide this!Advertise here!
My Leach Amp Clone (LEACH 150) panson_hk Solid State 32 22nd May 2014 11:25 AM
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 02:15 PM
anyone have leach PCB? ilyash Group Buys 2 7th September 2007 10:36 AM
Leach Superamp vs Leach 4.5 Samuel Jayaraj Solid State 4 26th October 2002 09:20 AM
Leach amp vs super Leach amp supernet Solid State 0 21st February 2002 10:16 PM
