Apexjr new transformer
Old 3rd February 2006, 08:40 PM   #1
jaudio is offline jaudio
Default Apexjr new transformer
Anybody know anything about this transformer,it is a new item at Apexjr.
What is the current for each secondary?
Is the secondary voltage depend on which primary tap you used?
Old 3rd February 2006, 08:42 PM   #2
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
is there a link to Apex Jr's website?
Old 3rd February 2006, 08:46 PM   #3
1/137 is offline 1/137
1/137's Avatar
Send a message via Yahoo to 1/137 Apexjr new transformer
2 centertapped 28 VAC secondary windings...40 lbs of transformer...there is a nice picture on the web site under the new section....click on the picture there and you will get a larger one...here it is
http://www.apexjr.com/images/bigtranny2.jpg
rt
Old 3rd February 2006, 09:39 PM   #4
6 1/2" X 5 1/2" X 8" , Primary 0 - 105V - 115V - 125V, Secondary... Dual 28V - Dual 14V and 0, 60 Amps - 30 Amps each side, WEIGHT 40 lbs each $ 45.00
Old 3rd February 2006, 10:30 PM   #5
1/137's Avatar
So there is NO confusion...this transformer has dual 28 VAC center tapped secondary windings each rated at 30 amps.
105, 115 and & 125 VAC inputs
rt
Old 7th February 2006, 07:38 PM   #6
Can someone clear this up for me?
How many secondary taps are there on this transformer?
Old 7th February 2006, 07:42 PM   #7
1/137's Avatar
There are 2 28 VAC center tapped secondary windings...
There is NOT a set of 28's AND a set of 14's...
What there is ...is 2 28 VAC center tapped windings.
It's clear from the picture...click on the picture for a better view
rt
Old 7th February 2006, 07:50 PM   #8
What is the VA total for both 28volt secondary winding?
Old 7th February 2006, 08:22 PM   #9
1/137's Avatar
The spec sheet says 28 VAC @ 30 amp...each winding..
rt
Old 7th February 2006, 10:30 PM   #10
Ok that would be 840va per 28volt winding or 1680 for both 28 windings? If the transformer has the capacitly of 2Kva,the that is 60va per 14volt winding or 120va for both 14volt winding?
Apexjr new transformerHide this!Advertise here!
ApexJr super8 fun theNoid Subwoofers 14 1st December 2006 08:16 PM
ApexJr AlephX? tiroth Pass Labs 5 8th February 2004 01:58 AM
Buying from Apexjr - UK Paulr Swap Meet 4 26th June 2003 10:57 AM
ApexJr Alesis Amp Modules.. Ignite Solid State 3 13th January 2002 05:00 PM
Copyright ©1999-2017 diyAudio
