480vac transformer used with 120vac? for a chipamp?! - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd February 2006, 11:29 PM   #1
zenon is offline zenon  Canada
Default 480vac transformer used with 120vac? for a chipamp?!
I have a couple 480VAC input transformers which are rated at 24VAC output. They are each 50VA.
If I were running them @ 120VAC input would each transformer then support 200VA? or does the 50VA hold true, but with the lesser voltage they can support much more current?
It seems to me that if they are running with 1/4 the voltage they're designed to that they should support more power then they are rated at.
[http://www.audiosector.com/lm4780%20psu.pdf]
Finally, I'd like to know if I can run one transformer into the AC1 inputs and a second into the AC2 inputs.
will the amp then see:
24/4= 6vac -> 6*1.414= 8.484vdc -> 8.484*2=16.968vdc
TIA
Old 2nd February 2006, 11:53 PM   #2
mrlots2do's Avatar
Default Re: 480vac transformer used with 120vac? for a chipamp?!
The secondary voltage should be 6vac.
Old 2nd February 2006, 11:59 PM   #3
leadbelly's Avatar
No
No, they were rated to give 2 amps, that's all you will get.
As for building a chipamp with them, DC voltage out of one will be roughly 6 * 1.414 - 1.4 = approx 7 volts. Even with 2, I wouldn't bother except maybe a tweeter amp.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 3rd February 2006, 02:17 AM   #4
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
TIA
This violates most electronics laws.
Transformers have a volts/second per turn rating (shared by all windings) that should not be exceeded in order to prevent core saturation, and a rms current rating for each winding that should not be exceeded to prevent overheating. The VA rating is something that was invented to allow people not understanding transformers to talk about them.
Since the maximum allowed rms current through each winding is limited, maximum power output is reduced proportionally to input voltage. Thus the higher the input voltage, the more optimum the usage of the transformer is.
Old 3rd February 2006, 06:05 PM   #5
each secondary winding must not exceed it's design current limit.
If you run a 480Vac transformer at 25% of primary voltage you get 25% of output voltage. Multiply V times A and you end up with 25% of VA rating.
The proportion of undervoltage equals the proportion of effective VA rating. i.e. half voltage=half VA and quarter voltage =quarter VA.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 7th February 2006, 07:52 PM   #6
Another way of looking at it, which supports the advice above; the secondary is wound with a certain gauge wire, with an associated resistance. The copper loss in the secondary will be I (the current) squared times that resistance, generating a certain amount of heat. Irrespective of the voltage, this heat is purely generated by the current. So doubling the output current draw would increase the loss by four times, and things might start smelling funny. And of course doubling the output current would double the input current, with the same problem on the primary winding.
WTB: 120VAC->15VAC 80VA transformer 454Casull Swap Meet 0 25th October 2008 04:01 AM
Chipamp.com PSU with CT transformer cabbagerat Chip Amps 8 1st February 2008 02:40 PM
Heatsinking/transformer for big chipamp? Arx Chip Amps 5 3rd March 2007 09:20 AM
Will this transformer work with the ChipAmp kit? Spasticteapot Chip Amps 8 18th January 2006 11:58 AM
Copyright 1999-2017 diyAudio
