Go Back   Home > Forums > Amplifiers > Power Supplies
Old 27th January 2006, 02:38 PM   #11
poobah is offline poobah  United States
poobah's Avatar
Ah ha...
hmmmmm.
So is this caused by assymmetry in bass signals... or just bass in general?
Eva is on the opposite side of world I think... probably sleeping still?
Old 27th January 2006, 02:43 PM   #12
zilog is offline zilog  Sweden
Originally posted by poobah
Ah ha...
hmmmmm.
Rail pumping occurs as soon as you have output voltage != 0, the lower the frequency of the output wave, the greater the pumping. Eva should be awake, I think she's in my time zone
Old 29th January 2006, 08:12 AM   #13
subwo1 is offline subwo1  United States
subwo1's Avatar
I guess I'll throw in a thought. The main pumping mechanism in a class D amp would occur when a power supply rail passes enough net current through the output filter inductor for a sufficient length of time.
When a MOSFET turns off, the voltage on the inductor flies back to the opposing power rail momentarily adding charge to its filter capacitor either through the body diode if the MOSFET there has not turned on yet, or through the channel if it has already turned on. If the net voltage at the output load is zero, the cycle-by-cycle voltage increases on the power supply filter capacitors keep transferring back and forth evenly, with neither capacitor building up extra net voltage. Net current passing through output inductor for any appreciable length of time will pump up one of the power supply rails, the greater the current, the greater the pump-up. For this reason, DC output voltage offset into a low resistance produces the serious pumping.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 29th January 2006, 09:13 AM   #14
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I'm awake
I have not experimented with class-D at all, but if we analyse it as a simple buck converter, then the so called "rail pumping" effect becomes a logical consequence of output filter resonance (peaking at HF).
Note that in any buck converter suffering from output filter peaking you may actually get AC output voltages whose peak value is higher than the input voltage, provided the system is excited at the right frequency.
Old 29th January 2006, 10:28 AM   #15
Eva's Avatar
I'm sure that it was invented long ago, but a simple voltage balancer like this should avoid any supply pumping issue:
The switches should be operated in a complementary way but with some dead time to allow the transformer to self-balance (with the help of strong RC snubbers that would produce rise/fall times proportional to magnetizing currents).
Old 29th January 2006, 06:25 PM   #16
Eva,
It looks like a solution, but wont efficiency become suffering if I cant manage to get my smps transformer turns ratio equal?
Would it be possible to use this configuration together with a single voltage smps to create a dual output voltage smps by using the balancer to create a fake ground?
Old 29th January 2006, 08:24 PM   #17
Eva's Avatar
That sounds interesting... Yes, you can use such a balancer to keep a virtual ground centered between both rails, but don't expect this to cause so much complexity reduction in the main SMPS. On the other hand, if the main SMPS lacked a ground output, then the balancer would have to work harder.
Old 29th January 2006, 09:58 PM   #18
Eva,
You dont have any web reference to this voltage balancer? I feel like I need some guidance as I dont really understand how to design snubbers etc. I also wonder how I should incorporate this circuit into my smps, I suspect that I need to make extraordinary things to the voltage mode feedback loop in order to make this work.
Old 29th January 2006, 10:44 PM   #19
Another thing I am uncertain of is how to decide on things like switching frequency, duty cycle (I guess as large as snubber reset allows), magnetic core size (how does core loss depend on pumped current/voltage?). I guess a too low switching frequency in the voltage balancer will cause excessive ripple voltage on my rails.
Old 7th March 2006, 07:55 AM   #20
I still wonder if this balancer is feasible in a practical circuit - wont the voltage difference between my two secondary windings be forced to be equal - and thus forcing the offset voltage to dissipate through the copper resistance of the transformer secondaries?
I am thinking about using this circuit but with a hysteresis scheme that prevents if from operating with less than say 1V voltage difference. Also I guess the balancer will need to switch synchronous with the primary switches to avoid unneccesary beating effetcs.
Half Bridge offline SMPS mag Power Supplies 8 18th September 2008 10:05 AM
help me abou the calculation of half-bridge smps ? mahmood Power Supplies 4 4th April 2008 06:00 AM
transformer supplier for half bridge SMPS jegandren Parts 0 29th February 2008 12:43 PM
help me with a half bridge smps(sg3525) red_zone003 Power Supplies 10 22nd November 2007 11:27 PM
Whats the difference between full bridge and half-bridge SMPS ? skaara Class D 6 3rd February 2005 07:23 PM
Copyright ©1999-2013 diyAudio
