Hi guys,
How you do connect a protection diode to a 7912??...ive a high value cap at the output. I want to protect the regulator when the cap is discharging |
#2 |
Connect between input and output of the regulator. Anode to input. Normally it will not conduct, but if the input is shorted, will discharge the output capacitor. Regulators with outputs exceeding about 7V need this protection to prevent base emitter reverse breakdown.
A 1N4004 is usually OK |
#3 |
doesn't really make sense. For my case whihc is a negative regulator, when the system is switched off, the cap at the o/p will discharge. However by connecting anode to input, doesnt it restrict the follow of current to the input of the IC? This might make the cap discharge into the output of the regulator thereby destroying it?
#4 | |
#5 | |
#6 |
Input is going to be around -17V, output is -12V so the bar end (cathode) should be to output so that the diode is reverse biased.
#7 |
That's what I was thinking.
#8 | |
Yes, you are right best |
#9 |
However in this cap suppose i have a large value cap at the o/p and it discharges. The diode will not protect the o/p of the regulator as it si reversed right? So doesnt it make the diode useless?
#10 |
Hope this solves the doubt...
SivanandBalan |
| Reverse polarity protection, better way without diode. | guiseppim | Class D | 5 | 19th May 2009 07:44 AM |
| Anti-reverse-bias protection diode vs. performance | hollowman | Power Supplies | 5 | 28th September 2008 11:15 PM |
| Need a CRD E-102 (current regulator diode) | ostie01 | Parts | 2 | 10th August 2006 09:13 PM |
| Diode protection: Quick Question | 2sb18 | Chip Amps | 4 | 2nd March 2006 07:44 PM |
| 3-terminal regulator IC protection | metebalci | Parts | 0 | 4th May 2004 08:46 PM |
