Regulator idea - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd January 2006, 10:27 PM   #1
darkfenriz's Avatar
Default Regulator idea
Attached is an idea of regulating voltage by both subtracting the noise signal (error feedforward? ) and vintage output stage follower with local feedback.
What would you think?
I'm waiting for comments.
Values are rather random at the picture. And sorry for quality
Old 23rd January 2006, 06:52 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
Why don't you put it into a simulator and see how it goes?
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 23rd January 2006, 07:11 AM   #3
jan.didden's Avatar
Default Re: Regulator idea
How does it work?
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 23rd January 2006, 07:53 AM   #4
darkfenriz's Avatar
Default Re: Re: Regulator idea
Originally posted by janneman
How does it work?
For now it doesn't
seriously, the idea is to make the first bjt from the left sense any differences between reference voltage and unregulated input. The input thru divider feeds the base, difference to be at emitter resistor (100R), this is hopefully subtracted by drop on 470R.
Old 23rd January 2006, 07:59 AM   #5
darkfenriz's Avatar
The second step is emitter follower (first bjt from right at original picture) with local feedback performed by middle bjt, this one also causes drop on the same 470R.
And once more sorry for quality. My computer broke some time ago and I don't have any simulator now, neither I want to run unknown circuitry without your 'approval' . That's why I drew it in MSPaint
Old 23rd January 2006, 08:30 AM   #6
jan.didden's Avatar
Default Re: Re: Re: Regulator idea
For now it doesn't
OK, the sense will work. But what does it do then? Ahh I see, you want to adjust Vout as a function of the input ripple? Kind of error feedforward? I don't think you can dimension it such that it exactly cancels any output ripple. In fact, that is what the right bjt tries to do, isn't it?
Jan Didden
Old 23rd January 2006, 08:56 AM   #7
darkfenriz's Avatar
Default Re: Re: Re: Re: Regulator idea
Probably you are right, Jan.
Something like 30dB of forward error cancellation would be good news. However I would expect this mechanism to work across relatively wide band, because it does not have the limitations of feedback, which can be very low at radio frequencies. My wishful thinking says also something about ripple transient response , but... You make great work keeping poeple down to earth
Best regards
Adam
Old 23rd January 2006, 09:28 AM   #8
jan.didden's Avatar
Default Re: Re: Re: Re: Re: Regulator idea
Best regards
Adam
These feedforward schemes often depend on knowing the exact impedance or gain or whatever of the circuit you are trying to correct. That generally isn't possible, unless you make one or two parameters adjustable so you have to tune each circuit individually. It's doable but not attractive because it brings other problems.
Your idea might work in another way, like you put the output noise into an opamp with gain = 1/feedback divider and subtract it from the bottom of the feedback divider. That would work in theory, but because of uncertainties in the exact value of the feedback divider (you will need two exact resistor ratios) and non-linearities in even the best opamps, it is probable that it doesn't improve on the basic feedback regulator. These are often things that work in Spice with exact equal or ideal components but not in practise.
Jan Didden
Old 23rd January 2006, 11:55 AM   #9
lineup is offline lineup  Sweden
lineup's Avatar
In this kind of 'vintage' regulator, NPN pass transistor,
it is possible to let current source for V-ref be fead from the output.
I often make lowdrop ( <0.050 Volt in-out ) regulators with a PNP to pass the output.
Regulators with very low supply current consumption and low drop Voltage,
for possibility to effectively use battery for powering audio circuits.
In these PNP circuits, I have to use other methods
to be able to feed V-ref from output.
Sometimes a high value resistor from input to V-ref to give a small startup current,
sometimes I use a simple 'start up pulse generator' from input.
lineup
Zener regulator with "integrated" pre-regulator 00940 Power Supplies 17 22nd July 2008 05:11 PM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 02:01 PM
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 08:18 AM
Another idea Bernhard Solid State 4 15th December 2005 07:50 AM
New CCS Idea sijosae Solid State 32 22nd September 2005 07:59 AM
Copyright ©1999-2017 diyAudio
