The Bridge Rectifier in the power supply of my Marantz amp is physically damaged. It's a square shaped part from Shindengen, 200V, 4 amp.
Could someone with more knowledge than me tell me if I have to replace it with the exact same value? I see for example that Radio Shack have a 200V 6 amp rectifier. I just want to put something in the circuit to see if it will work.
Alan
Alan
Probably my fault
Well...I'm embarrassed to say that at one time I took the two large caps out of the board and then replaced them..don't ask...and at that time I knew nothing about polarisation. So if I had them in the wrong way could that have damaged the rectifier?
I'm taking baby steps here
Schematic attached.
Alan
Schematic attached.
Alan
20 minutes! In my experience incorrectly polarised caps blow at switch on, and what a bang and mess they make!
The bridge rectifier you intend to use will be fine. I would look to increase the capacitors back to the original value of capacitance though, usually going down in capacitance is worse for performance.
- Power Supplies
- Bridge Rectifier question
