Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th January 2006, 11:16 AM   #11
Default rectifier
please my friend ,as per the circuit ,the caps that you replaced could have worked though the problem could have been the generated noise due the ripple factor on the supply, but try to confirm the functioning of other components.
Old 14th January 2006, 12:23 PM   #12
dnsey is offline dnsey  United Kingdom
If the polarity of the caps was wrong, that might well have damaged the rectifier. Unfortunately, it might also have damaged the caps
Old 14th January 2006, 02:13 PM   #13
poobah is offline poobah  United States
poobah's Avatar
If the polarity was wrong... it may take 20 minutes or more but he caps would have exploded! You would have known!
This could be just a simple rectifier problem... but you should look for other problems first...
Ping anatech, he is an amplifier doctor of many years.
Old 14th January 2006, 02:18 PM   #14
Did it Himself
richie00boy's Avatar
20 minutes! In my experience incorrectly polarised caps blow at switch on, and what a bang and mess they make!
The bridge rectifier you intend to use will be fine. I would look to increase the capacitors back to the original value of capacitance though, usually going down in capacitance is worse for performance.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 15th January 2006, 04:15 PM   #15
Cortez is offline Cortez  Hungary
Cortez's Avatar
4 MBR10100 in a rectifier bridge will be enough in current
to charge a 33000uF/63V cap in the starting phase ?
With a soft-start circuit of course (relay + timing + resistor).
Bridge rectifier voltage question woody Power Supplies 1 1st May 2008 12:47 AM
bridge rectifier question crippledchicken Power Supplies 31 25th April 2008 11:17 AM
Bridge Rectifier Question sam9 Solid State 3 16th October 2004 01:03 AM
Simple bridge rectifier question. JoeBob Everything Else 51 15th February 2002 07:46 PM
Page generated in 0.08240 seconds (70.66% PHP - 29.34% MySQL) with 11 queries
