Choke input 3 phase rectification voltage? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th January 2006, 11:28 PM   #1
Tweeker is offline Tweeker  United States
Default Choke input 3 phase rectification voltage?
If I were to use a 6 pulse bridge rectifier with a choke input LC filter, relative to the AC RMS voltage across each secondary, what DC voltage out would I get:
With delta connected secondaries?
With wye connected secondaries?
Be sure your foil hat has a good low impedance ground.
Old 12th January 2006, 11:36 PM   #2
poobah is offline poobah  United States
poobah's Avatar
Tweeker,
The ralationship between delta and wye is the square root of 3 (1.73). So if you measure 120 volts from leg to neutral (wye); you will measure 208 volts from leg to leg (delta... or wye for that matter).
Old 13th January 2006, 02:19 AM   #3
I know 3 phase wye bridge rectified without a choke but capacitor gives 2.45*VAC RMS= VDC, what does it give with a choke? 1.73*.9= 1.56?
With delta connected secondaries, does this mean output with choke would be VAC RMS * .9 = VDC?
What scant information I can find seems to indicate this isnt quite right, choke input polyphase rectifiers seem to be obsolete.
Old 13th January 2006, 03:13 AM   #4
poobah's Avatar
I will have to look... in a little red book I have...
Wait for tomorrow... I can't promise an answer... I just don't want to give you a BS one.
Old 13th January 2006, 06:21 AM   #5
In fact Im pretty sure it isnt * .9, average voltage would be much higher than with single phase.
Old 13th January 2006, 06:08 PM   #6
poobah's Avatar
hey Tweeker,
The average voltage factor is 0.954969. I couldn't find my little red book so I Armstrong-ed it in Excel... PM me if you want the spreadsheet.
Remeber, when you sum the 3 rectified phases the voltages don't add... they merely overlap... only the biggest voltage wins...
OH... this isn't RMS... multply by 1.414
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 05:43 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 02:32 PM
ac voltage after rectification raif Chip Amps 15 3rd June 2005 12:10 PM
Negative Voltage with Tube Rectification? commstech Tubes / Valves 7 16th July 2004 05:40 AM
Choke-Input: How do I calculate the right snubber for high-current-low-voltage Blitz Solid State 20 24th March 2004 09:37 PM
Copyright 1999-2017 diyAudio
