MOSFETs (active rectification) in place of diodes in linear PSU
Old 17th January 2006, 03:25 PM   #41
UnixMan is offline UnixMan  Italy
UnixMan's Avatar
Originally posted by Eva
In order to trigger a thyristor, a small current should be made to flow from gate to cathode, so you should connect the secondaries of the pulse transformer between these legs.
OK... BTW, I would say that the return path was there already (via the ground connection).
There is no point in inserting the secondary windings of the main transformer in the trigger loop.
how would you sync the PWM driver to the mains frequency, then?
As a control circuit you may consider the good old TL494 synchronized to the 50/60Hz waveform and with its internal clock programmed for 40Hz or so operation. The TL494 will be fine since it
I'll have a look at it...
I forgot to mention that you are going to need some kind of high frequency pulse generator with on/off in order to feed the trigger transformer. A LM393 comparator may do the job
that could be done... but wouldn't a simple CR do the trick?
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 17th January 2006, 03:42 PM   #42
UnixMan's Avatar
Originally posted by poobah
I believe nearly all transformers with voltages for tube B+ will have center taps.
except the one I have.
Indeed, in my case (having only ~220Vac on the secondary) I've been a bit dumb not choosing a center-tapped PT, even if I was planning on using sand anyway.
But if you consider a PSU for tubes which requires several hundred or even over 1 KV dc, using a center-tap PT would be rather troublesome, or at least quite expensive.
I would focus on the control strategy and topology... the fine points of design. Then, decide which SCR layout makes the most sense to you.
agreed.
Just a thought, there may be silicon modules for light dimming that may be useful for AC synch and control of "firing angle"... might save you a lot of parts.
mmmh... intersting idea... it's definitely worth some search...
Old 17th January 2006, 04:19 PM   #43
poobah is offline poobah  United States
poobah's Avatar
In any topology you will need a second low voltage winding to derive "house keeping power" for the start-up control. This winding can provide synch.
If you have no center tap, you are forced to use 2 diodes and 2 scr's.
Old 17th January 2006, 04:34 PM   #44
Lars Clausen is offline Lars Clausen  Denmark
We use it commercial products with good results.
Per Anders: I have always been wondering where you work in the daytime
All the best from
Lars
www.newclassd.com
Old 18th January 2006, 07:45 PM   #45
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
peranders:
Ouch!!
I have seen these BTSxxx ICs priced anywhere from 3 euro/piece the lowest current models to 12 euro/piece the 8 miliohm version, so I think that I will continue with my discrete solutions...
MOSFETs (active rectification) in place of diodes in linear PSUHide this!Advertise here!
Most linear region of Mosfets ? Bernhard Solid State 15 11th March 2009 04:00 PM
New Linear MOSFETs from IXYS Kashmire Pass Labs 3 27th April 2007 11:39 AM
Using Mosfets as Diodes jkeny Power Supplies 5 26th October 2006 09:15 AM
has anyone tried On-Semi's MOSFETS in place if IRF's? bigparsnip Pass Labs 7 28th February 2004 02:30 PM
How do you select the transistors (or mosfets, rectifier diodes, etc) to use? Bricolo Parts 8 17th September 2003 02:11 PM
