Transformer/rectifier wiring - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 9th January 2006, 09:23 PM   #1
Jonhny is offline Jonhny  Sweden
Default Transformer/rectifier wiring
I have a transformer with 5 wires. Two mains, a centertap and the two hot wires. 2x27 VAC
Can I wire it and the rectifiers/caps in a way that I get 27x1,41~1x38 VDC with as much current as possible?
Old 9th January 2006, 09:26 PM   #2
costiss's Avatar
you could use a full wave rectifier (two diodes) but the current capability will be severely compromised..
i am currently using 60,000 uF of capacitance in my preamplifier..
Old 9th January 2006, 09:55 PM   #3
K-amps is offline K-amps  United States
K-amps's Avatar
Why not parallel the secondaries to double the current at 27vac? Perhaps I misunderstand your question...
Old 9th January 2006, 10:16 PM   #4
Since it is a center tap and I can't access the two windings seperatly I don't know exactly what to do. If I put the two hot wires together I'm pretty sure there will be a fire since they are out of phase.
Double full-wave bridges with outputs connected?
Old 9th January 2006, 10:21 PM   #5
K-amps's Avatar
Pardon me, you are correct, here in the US, most of the new Toroids come as dual sec windings which you rig up for Center tap OR parallel connection. I do know that some are hardwired as a center tap. I just made a few Toroid connections in my projects and was in "that" frame of mind.
Cheers.
Old 9th January 2006, 10:27 PM   #6
I'm used to transformers with seperated wires too, but this one is free so I can't complain. Worst case scenario is that I have to open it up and see if I can get another wire out of it.
Old 9th January 2006, 10:56 PM   #7
lineup is offline lineup  Sweden
lineup's Avatar
I found a webpage
that gives formulas for different possibilities
to make DC out of transformer.
Formulas is to decide what is minimum rating for trafo
when you need a specific DC voltage and max current.
These formulas can be rewritten to give you resulting DC voltage
and max Current for a given Trafo and method of rectifying.
Also if you use a filter capacitor will effect result.
Transformer VA Calculations
Half Wave Rectifier (HWR)
Full Wave Center Tap (FWCT)
Full Wave Bridge (FWB)
Dual Complementary Rectifies (DCR)
Adding A Regulator
lineup
Old 9th January 2006, 11:02 PM   #8
K-amps's Avatar
Originally posted by lineup
I found a webpage
Good page! I put it in my favs.
Old 9th January 2006, 11:17 PM   #9
Thanks!
The full wave center tap is not that bad, at low voltages at least. Guess I will try it.
Old 4th February 2006, 09:02 AM   #10
Cortez is offline Cortez  Hungary
Cortez's Avatar
I have a shield copper-foil layer on the primer, and the core has also a wire for grounding.
Where should I connect these wires ? To the earth on the primer side, or to the GND on the secunder (DC) side ?
Rectifier for lighting transformer Atilla Power Supplies 6 23rd February 2009 08:49 AM
Wiring a tube rectifier PSU cbutterworth Tubes / Valves 8 18th September 2007 08:42 PM
half wave rectifier will not saturate transformer core? vax9000 Power Supplies 1 2nd November 2006 04:33 AM
Distance Transformer > Rectifier Magsy Chip Amps 10 1st December 2005 12:03 AM
simple transformer/rectifier problem... maxw Power Supplies 7 10th August 2005 11:55 PM
Copyright 1999-2017 diyAudio
