PSU with Simple Source Follower Regulator
Old 2nd February 2006, 12:31 PM   #31
R.I.P.
Hi Eva,
is your ground symbol connected to the correct end of the load?
As drawn this is the +ve rail supply.
regards Andrew T.
Old 2nd February 2006, 12:41 PM   #32
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Yes, I intentionally arranged it this way to show the possibility of grounding the tabs of the TO-220 devices and using the metal case of the project as a heatsink without mica or sil-pad insulators nor plastic washers. This requires independent floating transformer windings for each supply (not center tapped), though.
Having floating transformer secondaries also allows to employ cheaper N-channel devices for both positive and negative rails, altough the tabs of the power devices from the negative rail won't be gounded and would require insulation.
Old 2nd February 2006, 03:49 PM   #33
Onvinyl is offline Onvinyl
Onvinyl's Avatar
that may be a basic question as well; but how to choose a 'low impedance point' where all currents return with such a floating design?
Is it wise to have different grounds?
Rüdiger
Old 2nd February 2006, 03:57 PM   #34
Eva's Avatar
Only the transformer winding is floating in that design and this is fine as long as the same winding is not employed for anything else. The output of the regulator is not floating, it's grounded... In fact it's ground!
This ground is the one you should use for the rest of the circuit.
PSU with Simple Source Follower RegulatorHide this!Advertise here!
Zener + Emitter Follower voltage regulator Alcaid Solid State 90 1st June 2010 11:12 PM
Source follower and common source output stages slogan2112 Pass Labs 2 9th October 2008 08:19 PM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 12:55 PM
Fet Follower Regulator On Resistance? macka Pass Labs 2 25th December 2004 03:35 AM
Source follower electret mike -> use with current source? capslock Solid State 1 28th February 2003 12:54 PM
