Basic high voltage regulated supply
Old 22nd January 2006, 02:07 AM   #31
awpagan is offline awpagan  Australia
sent
Indecision makes the world gone round.
Maybe
Old 22nd January 2006, 03:16 AM   #32
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally posted by awpagan
300v rail easy to work out but 600v?
? could reference off the 300v or bypass like this thread.
any suggestions???
you can use a pair of big Hexfets -- one as an inverting amplifier to drive the gate of the second -- the basic circuit is described in H&H -- here's a link to a version I used at one time (it is scaled to 400V but can be built for 600V) -- it used a voltage doubler and inverting amplifier scheme:
http://www.tech-diy.com/MCTracer_no_...pplyIR_FET.jpg
Old 22nd January 2006, 03:30 AM   #33
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I think that such high voltages as 600V are easier to regulate by means of a flyback converter, or a flyback pre-converter outputing something quite close to the desired output voltage and then a linear regulator that won't be required to whitstand high voltages or dissipations. Current limiting may be performed also in the flyback, making things even simpler.
Old 22nd January 2006, 04:05 AM   #34
jackinnj and Eva, thank guys.
I already have the transforner ~700 centre tapped
don't need to voltage double, and switchmode in audio
first time i've seen a "Supertex developed a nice little (TO-92) regulator which will "do" 1.2 to 450 V -- the LR8N3"
easy enough to reg 300v
but if it like the "317's" i was thinking about base "reference" to the 300v line to get the 600v
does the LR8N3 only handle ~430v or voltage drop.
same as the 317's handle ~40v drop.
buy raising the "ground" voltage to say 30v adjust could be up to 70v
allan
ps if you get what i mean
Maybe
Old 22nd January 2006, 05:09 AM   #35
Eva's Avatar
You can raise the ground if you want, it works. But a lot of problems will arise during overload conditions. Also, you should make some room for line fluctuations, for example, your target output voltage should be obtainable with mains input voltages from 180V to 250V AC (80 to 130V or something like that) if you want your equipment to be smart enough to work almost everywhere. This may be a bit challenging for a linear 600V regulator, and if you want to use a standard LM317 or similar you will have to fit a pre-regulator to protect it against overvoltage.
Old 22nd January 2006, 06:04 AM   #36
just dug out the old amp
hammond 374 trans 750v centre tapped
so just over 1000v dc 500vdc centre
so unless i pre-reg this to drop volts, Its too high for the LR8N3 anyway.
allan
Maybe
Old 22nd January 2006, 01:38 PM   #37
jackinnj's Avatar
The point of the schematic which I showed wasnt' the voltage doubler -- it was the inverting amplifier regulating via an opamp error amp. instead of a DAC (a variable reference) use a high quality, low noise reference.
Eva's points are well taken -- an LM317 is only going to regulate a small portion of the possible variation in input voltage.
Sorensen makes regulated HV supplies using (I believe) forward technology, synchronous rectification, current mode control. These things are designed by teams of engineers at Raytheon -- not for the faint of heart.
Basic high voltage regulated supplyHide this!Advertise here!
Lost Thread-High VOltage Regulated Power Supply LinuksGuru Tubes / Valves 2 21st June 2009 01:48 AM
regulated power supply for high powered amps. marchel Solid State 14 5th March 2009 09:00 AM
Leach amp - regulated supply only for the voltage gain stages? velicko Solid State 2 21st January 2008 11:16 AM
About high voltage regulated power supplies wd40 Tubes / Valves 4 25th March 2004 03:16 AM
high-voltage regulated dual power supply zzz Solid State 1 17th September 2002 01:15 AM
Copyright ©1999-2017 diyAudio
