Basic high voltage regulated supply
Old 27th December 2005, 12:48 PM   #21
Jay is offline Jay  Indonesia
Banned
Originally posted by quasi
The circuit at first glance could look like it uses the transistors as a booster stage carrying the bulk of the current
That's what I have in mind.
Finally the circuit will work with any 3 pin regulator any 78xx & 79xx. The ouput voltage will be the sum of the zener(s) plus the regulator voltage.
Ha! That's a very good news I just might need to buy some other zeners...
Old 27th December 2005, 01:26 PM   #22
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Supertex developed a nice little (TO-92) regulator which will "do" 1.2 to 450 V -- the LR8N3 -- it's stated purpose seems to be controlling the high voltage on the front-end of an off-line switching power supply. Of course it is also applicable as a regulator to control the base of a pass transistor.
http://www.supertex.com/pdf/datasheets/LR8.pdf
www.mouser.com is their distributor in the U.S.
Old 22nd January 2006, 12:33 AM   #23
awpagan is offline awpagan  Australia
just saw this thread.
quasi
silicon chip used this idea for there ULD amp power supply +- 55v
Used 317/37's and trimpots for adjusting.
psu works well very versatile.
jackinnj
the LR8N3 looks interesting.
i need a 300v and 600v voltage lines for a valve amp.
been using zeners, because haven't found high voltage reg.
until now, thanks, food for thought.
300v rail easy to work out but 600v?
? could reference off the 300v or bypass like this thread.
any suggestions???
Indecision makes the world gone round.
Maybe
Old 22nd January 2006, 12:51 AM   #24
quasi is offline quasi  Australia
quasi's Avatar
I can't see why this would not work at 600v, using higher voltage transistors and capacitors and a current limiting input resistor(s) for a softer start. I'm not sure what voltage zeners you can get, I've got some 150v here so 4 of them would do it.
Old 22nd January 2006, 01:01 AM   #25
astouffer is offline astouffer  United States
astouffer's Avatar
What kind of preamp needs 600v?
Old 22nd January 2006, 02:10 AM   #26
quasi
3*150v 1*130v zeners with 20% tolerance made to total of 594v, close enough
farnel has zeners up to 270v
did have it working, then when putting in case, redesigned psu pcb,
not stable since
probably done somthing wrong
got sidetracked till i saw these regs.
astouffer
preamp?
built this fair while ago
http://headwize.com/projects/showfil...ilmore_prj.htm
allan
Maybe
Old 22nd January 2006, 02:14 AM   #27
quasi's Avatar
Hey awpagan,
are you saying that you had my PCB working up to 594 volts, the schematic or something else?
Cheers
Old 22nd January 2006, 02:25 AM   #28
oops sorry
just reread my post
Not your circuit but the one in the link using zeners and bu508's
this one
http://headwize.com/images/gilmore4.gif
allan
ps silicon chips circuit i can mail if you want?
Maybe
Old 22nd January 2006, 02:45 AM   #29
quasi's Avatar
Yes please.
Cheers
Old 22nd January 2006, 02:58 AM   #30
you have mail
cannot attach though diyaudio
please reply to email and i'll attach it
SC edition nov 2001
allan
Maybe
Basic high voltage regulated supplyHide this!Advertise here!
Lost Thread-High VOltage Regulated Power Supply LinuksGuru Tubes / Valves 2 21st June 2009 02:48 AM
regulated power supply for high powered amps. marchel Solid State 14 5th March 2009 10:00 AM
Leach amp - regulated supply only for the voltage gain stages? velicko Solid State 2 21st January 2008 12:16 PM
About high voltage regulated power supplies wd40 Tubes / Valves 4 25th March 2004 04:16 AM
high-voltage regulated dual power supply zzz Solid State 1 17th September 2002 02:15 AM
