Push-Pull converter with a gapped transformer ??
Old 25th December 2005, 03:38 PM   #31
Pjotr is offline Pjotr
Pjotr's Avatar
Hi Joseph,
To put it simple: In a flyback transformer all the transferred energy is stored in the transformer in the magnetic field. It is not really a transformer, merely 2 coupled inductors because there is no current in the primary and secondary at the same time. Since the ferrite cannot store much magnetic energy there is a need for an air gap that stores most of the energy to be transferred.
In a forward/pp transformer the transformer only stores its own magnetisation energy. So if you want to use a fb transformer as a normal transformer you have a much to much (and unnecessary) amount of stored energy to deal with.
Btw. It is most time possible to disassemble surplus transformers by heating them at app 100-120 deg C. The potting compound then usually weakens sufficiently. The heat plate of my coffeemaker works perfectly well for that
Cheers
Push-Pull converter with a gapped transformer ??Hide this!Advertise here!
primary winding for push-pull converter @100amps, 100kHz vena2a Power Supplies 175 15th May 2013 09:45 AM
Magnetizing Current in Push-Pull Converter scottieman Power Supplies 3 28th January 2005 06:47 AM
