Hi!!!
what is the diference between normal transformers and toroidal trasnformers? is there any advantage? I'm asking this because in Argentina i cant find any place to buy a 24+24 toroidal. I can only find 12V toroidals for 12V lamps. maybe i can use 4x12v toroidal to make 2x24v. is that worth? or just buy an old "EI" transformer? |
#2 |
From what I gather a toroidal transformer emitts much less flux which affects the audio.
Plus I think the eddy current is also lower. |
#3 |
Did it Himself
Smaller magnetic field (leakage), better VA and regulation for same size.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
EI pluses- lower bandwith, far more tolerance for DC offset. One way to deal with the flux is just have it a couple feet from the amp.
Be sure your foil hat has a good low impedance ground. |
#5 |
toroidal is really used because they are the cheapest per VA due to more efficient use of materials + investment in auto-winding
EI give better isolation from the line due to lower pri-sec parasitic C, they do have higher leakage flux, but is easily "short circuited" by cheap iron such as tin can stock or even galvanized sheet - some high end manufacturers put EI pwr xfmrs in drawn cylindrical cans to to get superior performance while avoiding questions from those brainwashed by toroidal="hi tech" hype |
#6 |
imho, you miss nothing if you just used EI's...
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#7 |
EIs have lower inrush
Badly made EIs tend to vibrate and buzz audibly |
#8 |
#9 |
thanks to all!!
70W x 4 + 100W = 380W of audio output 500va? 600va?
#10 |
Did it Himself
A good rule of thumb is VA = 2 x output RMS
| toroidal or not toroidal | alphadelta | Solid State | 5 | 22nd November 2004 04:58 PM |
| what toroidal should be used with GC | messylife | Chip Amps | 4 | 29th April 2004 12:31 AM |
| Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) | Rixsta | Pass Labs | 10 | 23rd April 2004 03:41 AM |
| toroidal question | saletel | Chip Amps | 1 | 15th December 2003 09:38 PM |
| toroidal | karma | Swap Meet | 3 | 14th March 2003 11:42 PM |
| Page generated in 0.09562 seconds (75.61% PHP - 24.39% MySQL) with 10 queries |
