Go Back   Home > Forums > Amplifiers > Power Supplies
Old 9th December 2005, 09:27 AM   #1
Baba24 is offline Baba24  United Kingdom
Default marantz cd player captive mains lead modding
Hi everyone,
How do you internally wire a Marantz ki sig cd player with an after market high grade iec kettle lead or alternatively ad an Iec inlet to the back of the unit for connection. If I had to solder it internally it has 2 wires brown [live] blue [neutral] what do you do with the earth wire from the mains cable?
Please note that I am a complete novice when it comes to soldering etc.
Anyone?
Old 13th December 2005, 12:43 AM   #2
phresh is offline phresh  United Kingdom
You could do this internally and add a socket to teh back if you didn't mind putting a hole in the case.
By far the easiest way would just be to add an in-line socket to the back as sold at Russ Andrews
I think this only uses screw terminals too so no need for solder!
Old 14th December 2005, 07:17 PM   #3
Fidelity Audio's Avatar
I have done this to both my KI cd and amp.
Buy yourself a clip in IEC socket.
Remove the original cable including the plastic grip.
You will now be left with a cut out.
After cutting out the difference slot in the IEC socket.
Now solder the live and neutral wires.
Dont wire in the earth, the chassis is a ground plane for both the analogue and digital circuits.
Hope this helps.
Modding a Marantz CD40 joydivision Digital Source 32 11th March 2011 05:55 AM
Best Pioneer player for modding wmj Digital Source 0 19th January 2007 03:04 AM
newbie question: screened mains lead ravbains67 Everything Else 41 17th May 2006 06:06 PM
marantz ki signature captive mains lead Baba24 Everything Else 1 13th December 2005 07:54 PM
Page generated in 0.07598 seconds (71.37% PHP - 28.63% MySQL) with 10 queries
