Offline full-bridge SMPS....need help - Page 121 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 18th July 2012, 11:12 AM   #1201
chas1 is offline chas1  Dominican Republic
Send a message via AIM to chas1 Send a message via MSN to chas1 Send a message via Yahoo to chas1
It would be easier to help with problem if you would provide schematic of your design
along with transformer contruction details,Your winding of transformer might be wrong.
seek and you shall find
Old 18th July 2012, 06:04 PM   #1202
Default car smps
how about this shematic?
i creat this one
when i conect battry cable the red led turn on
the mosfets is hote and exit voltage is +-5vdc
i use 4 irfz44n mosfets
can you creat this one?
thanks
Old 18th July 2012, 06:08 PM   #1203
i use this circute in 50khz
i use ETD39 core and irfz44n
Old 18th July 2012, 09:06 PM   #1204
I will look into it,I think I see the problem
Old 18th July 2012, 09:27 PM   #1205
Hi
In my country the oclock is 1:55am
Can i resive 15 amper or 20?
Can i use more irfz44 and etd39 for more power?
Where is the problem?
Old 19th July 2012, 04:10 PM   #1206
Default Transformer
I suspect your transformer is your problem; check this site for proper design
and construction.
New Page 1
Old 19th July 2012, 09:26 PM   #1207
Angry car smps
and construction.
New Page 1
where is my shematic wrong?why red led is turn on?when i dont conect the core that is turn on( red led)
Old 19th July 2012, 10:08 PM   #1208
The red led is connected to feedback(output of error amp) and will turn on red led when you apply power because of the way it is connected,look at P1,R13 connection and R14.I think if you adjust P1 you will get the red led to turn off(has nothing to do with why your supply does not work.Visit the website I provided and all will be explained ,Start with the correct core for the power requirements and wind it according to instructions,test the inductance with a VOM that has an inductance feature,fed a signal into the primary and check secondary signals.Refer to info at ESP website on checking transformers before mounting.Whatever control IC you use you should read the datasheet,check block diagram of internal circuit to understand its functions.Don't copy a design unless it has been proven to work and a proper PCB is supplied but if want to learn design in stages and check each one, start with control IC first(only requires a few components to function and you can do this on a bread board)apply feedback and check outputs to see the PWM signal and make sure it provides the correct outputs.Once you have the control part working the rest is cut and try to obtain the power you need(use dummy loads)only connect amp when all is well.
Old 19th July 2012, 10:23 PM   #1209
By the way mouse over (New Page 1) that will take you to a website that should clear up
a few of your questions...
Old 20th July 2012, 12:25 AM   #1210
Thanks for your reply
You doin best for me and i say very thanks to you my friend.
I see your web site
That smps work with sg3524
I try to find some think in my smps site but the site languich is turkish and main pdf file is rushen maybe.
I dont know this languich.
I try to find smps with tl494 because i have meny of them.
In main site of may smps they use irfz44 and etd 39.
I try to confige red led with pot1 but it was not work.
Can you advice to me one shematice of this topic?
Thanks my dear friend
Have a nise day
Copyright 1999-2017 diyAudio
