Offline full-bridge SMPS....need help
Old 7th December 2005, 01:22 PM   #11
Tekko is offline Tekko
Banned
You need to make like in the ESP car smps schem, use a npn and pnp bipolar transistor, one to turn the fets on and one to discharge the gate capacitance to allow the fets to switch as they should, otherwise it will not work. The SG3525 cannot drive the fets directly as its open collector and too low current handling.
Also you need to adjust the voltage feedback for the desired output, this is easiest done with a pot.
Old 7th December 2005, 01:25 PM   #12
sagarverma is offline sagarverma  India
sagarverma's Avatar
his design omits bjt's.he says sg is capable to directly drive gates(100 ohm res req.).i used that design and smps is happily working in car.
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum
Old 7th December 2005, 02:05 PM   #13
Nejc_car is offline Nejc_car  Slovenia
Do I have any other choise, but to use trafo for driving gates
Old 7th December 2005, 02:09 PM   #14
sagarverma's Avatar
use ESP design,good and works.
Old 7th December 2005, 02:13 PM   #15
If you mean for car I allready have it.
Old 7th December 2005, 02:45 PM   #16
sagarverma's Avatar
yes.
Old 7th December 2005, 02:49 PM   #17
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
You all have misunderstood the gate drive issue and the point of the whole thread. We were talking about high side drive in a full bridge off-line application, not about gate buffering nor 12V SMPS.
Obviously, such high side MOSFETs require a floating drive scheme, they can't be directly connected to a SG3525.
Old 7th December 2005, 03:08 PM   #18
sagarverma's Avatar
thanks for making this clear.
Old 7th December 2005, 03:19 PM   #19
Then my only option is to use trafo for driving gate's of the Mos-Fet's. Is it ok to use turn of 20:20+20 for gate trafo.
Old 7th December 2005, 05:12 PM   #20
Eva's Avatar
When designing such a transformer, leakage inductance should be minimised while maximising coupling between windings.
In practice, this is achieved by using the minimum number of turns that guarantees absence of core saturation for the operating frequency, voltage and temperature range, while filling the available width of the coil former (not including creepages). Sometimes, it's useful to wind bifilar or to split the primary in two (series or paralell) halves with the secondaries placed inbetween, etc...
The previous recommendations also apply to power transformers. You should figure out the optimum core size and magnet wire diameter.
The reason for a low leakage inductance is required in gate-drive transformers is that MOSFET turn-off times depend directly on it. When gate buffering is employed leakage inductance is no longer critical, though, but at the expense of an increased component count.
Offline full-bridge SMPS....need helpHide this!Advertise here!
