Offline full-bridge SMPS....need help
Old 27th January 2014, 06:34 PM   #1251
stewin is offline stewin  Kenya
hi all cool link diysmps and very useful Calculation programs for transformers and inductors diysmps
Old 10th March 2014, 10:36 PM   #1252
my latest lay out. but i will use external aux +12vlts
Old 13th March 2014, 10:25 AM   #1253
luka is offline luka  Slovenia
luka's Avatar
is this what I had just without -12v aux's? same size core, or did you go for 49?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 13th March 2014, 09:06 PM   #1254
i used the 12vlts using droppers but they got hot .so i prefered using small 12vlts power supply to start the oscilllation.
Old 19th March 2014, 08:13 PM   #1255
xeclipse is offline xeclipse  Kenya
Location: Where the world's best tea come from:Kericho Kenya
Hi Stewin, long time. According to mosfet datasheets, the maximum pulsed drain current is much higher (four times in IRFP 460- 80A) than the maximum continuous current. Since in smps the primary current is pulsed, I assume the maximum pulsed drain current is used when selecting a mosfet. Is there anyone who has had a mosfet failure related to overcurrent in the primary? That is assuming it was not dead time related failure.
Regards.
if there are no sparks,it probably doesn't work!
Old 21st March 2014, 06:22 PM   #1256
voltwide is offline voltwide  Ireland
There is a good chance to blow the MOSFETs during power up, when the transformer is shorted by the secondary caps,
or, in case the transformer is driven into saturation.
Old 5th May 2014, 08:28 AM   #1257
hi all by the way my above project worked perfectly with some few adjustments. i used irf740 and all was powerfull and o.k
now i wanted to do one with protection and transformer gate drive . as to do a full bridge in the near future.
Old 12th May 2014, 01:31 PM   #1258
fhoenix is offline fhoenix  United States
good design sir stewin
Old 19th May 2014, 09:40 PM   #1259
chas1 is offline chas1  Dominican Republic
Send a message via AIM to chas1 Send a message via MSN to chas1 Send a message via Yahoo to chas1
Default ATLK6 smps simulation
In this thread the the K6 smps there were questions if it worked as designed, so I am posting all the LTspice simulations I used to simulate the design and you can be the judge.In order to run the simulations you must have a copy of LTspice which is a free download, then make a folder in LTspiceIV and name it atl or any other name you choose.Remember to make simulations run faster only the bare bones are used but I think its ok.I have tested the zip file( I used Jzip) is complete but if have problems or you get an error that something is missing, let me know.Feel free to comment or make additions as this might help other DIY who lack spice experience.I tested the 42volt,56volt and 82 volt outputs as well as simulating a short on the outputs,by no means is this a complete design it is only for simulation,try it..
seek and you shall find
Old 19th May 2014, 10:33 PM   #1260
hi all the smps works well i am from testing it.the transfomer gate drive i wound it bifiliar mode .and the protection does indeed work,but i will do more tests and posts pics and results
Offline full-bridge SMPS....need helpHide this!Advertise here!
