Offline full-bridge SMPS....need help
Old 19th March 2013, 01:29 AM   #1231
joab ribeiro is offline joab ribeiro  Brazil
galera alguem tem layout desa fonte que o amigo ravslanka postou aguardo
Old 19th March 2013, 01:36 AM   #1232
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by joab ribeiro View Post
guys somebody has source layout challenges that await posted ravslanka friend
English please
dave
Old 19th March 2013, 02:08 AM   #1233
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Slightly more precise:
"hey guys , does anybody have the layout of that PSU posted by our friend ravslanska?
Waiting for an answer."
Old 22nd July 2013, 08:15 PM   #1234
stewin is offline stewin  Kenya
my latest smps project just tested it and works o.k
http://www.diyaudio.com/forums/class...ml#post3536038
Old 27th July 2013, 06:05 PM   #1235
more photos
ucd 25 watts to 1200 watts using 2 mosfets
http://www.diyaudio.com/forums/class...ml#post3573493
thanks all
Old 9th August 2013, 10:00 PM   #1236
hi all i have managed to get my hands on a few old used ups . they had the below igbts . can any of them be useful with ee55 to give 3.5kwt ?
IRGP30B120KD-E , IRG4PH40UD2 , K30N60 , IRG4PF50WD , k40T120 , IRG4PC50U , IRG4PC40U ,
thanking you in advance
Old 22nd December 2013, 07:09 AM   #1237
Old 20th January 2014, 07:11 AM   #1238
hi all the ir2110 version smps based on luka schema works well . but i want to try out the ir2153 version because it has few components. speaking of few components detexaudio 1200smps has the least components but it is a hustle for me to coil 220 turns on the small former.
my high power version of ir2153 smps with protection based on microsim schematic any comments or ideas are highly welcomed
http://www.diysmps.com/forums/showth...ll=1#post10055
Old 20th January 2014, 10:03 AM   #1239
chas1 is offline chas1  Dominican Republic
Send a message via AIM to chas1 Send a message via MSN to chas1 Send a message via Yahoo to chas1
Stewin
Have you thought about the delay in the protection circuit's, also I think with some small component changes you can simplify this design, the other is why the daughter card?, also use IGBT's junk the IRFP460's.The fsw is below 50kHz there are many low cost's IGBT's that can replace the 460's and the driver circuits can be simplified.Also the SG3525 can be used as a fixed frequency controller and provide higher fsw's,smaller magnetic components and has built in protection or better yet MC34025.My thought's only.I will post a design shortly.An after thought I would use a small house keeping supply for 24,12 volt supply because any short in you fan or aux circuit could cause a major failure in your main's supply.
seek and you shall find
Old 20th January 2014, 03:53 PM   #1240
Default Another IR2153 supply
Found this on net, check drive for FET'S simpler,protection looks solid,you can use your resistors in lower FET source if you like but what a power waste,current transformer best solution.
Offline full-bridge SMPS....need helpHide this!Advertise here!
Copyright ©1999-2017 diyAudio
