dc-filtering-ac-power-station
Old 2nd December 2005, 02:09 AM   #1
jh6you is offline jh6you
Account Disabled
Default dc-filtering-ac-power-station
Hi
Days ago, I fixed dc-blockers for my BOSOZ and F1 and found that they were working well (reference thread: Forte Audio 1a). And, I got real effect much better than other tweaks with quality of wires or components.
Therefore, I am going to make, say, a dc-filtering-ac-supply-station as shown below. The chassis will be of aluminum and will be directly connected to the earth. This station will cover Pass F1, BOSOZ, CD player and DVD projector.
Do you have any opinion or advice?
Particularly, regarding !!! SAFETY !!! of life. . .
jH
Old 2nd December 2005, 01:20 PM   #2
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, JH,
How are you
I just replace the cap for my bench drill machine, the cap is something like 10uF, 400VAC. Some of the proamps with SMPS also got cap in their AC input, but not that size (10.000uF), I think. Is it OK to put 50VDC cap for 220VAC?
Old 2nd December 2005, 01:35 PM   #3
DIAR is offline DIAR  Finland
DIAR's Avatar
The voltage over the capacitor is only few volts.
Here's how I built my dc blocker (which turned out to be useless). Home made circuit board with thick and wide traces.
http://www.diyaudio.com/forums/showt...=&pagenumber=2
Old 2nd December 2005, 02:37 PM   #4
steenoe is offline steenoe  Denmark
steenoe's Avatar
Here is a few gadgets for cleaning up the AC supply. Just scroll down the page
http://www.lcaudio.com/index.php?page=12
Just for inspiration. With schematics.
Steen
Old 2nd December 2005, 02:39 PM   #5
Account Disabled
Hi Lumanauw
I'm fine thanks
The bigger, the berrerrrrrrrr . . . . . . maybe.
The polarized electrolytic capacitor doesn't like to see overvoltage or reversevoltage. If capacitor sees the overvoltage or the reversevoltage, it becomes hot temper, and boils the yellow blood inside, and gets high blood pressure, and BAM !!!!!!! Meanwhile, the barrier potential of the bridge diode is about 0.7V. Luckily, the capacitor hardly see voltages higher than +/- 0.7V in this case. -- [i]my hope[i/]
Question: how much reversevoltage we could safely ignore?
Lumanauw, this is your homework. Solve it and tell me
jH
Thanks, Diar and steenoe.
Old 2nd December 2005, 03:38 PM   #6
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
if you want even more effect you could try ac-balanced-power combined with the dc-filters.
http://www.diyaudio.com/forums/showt...802&highlight=
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 2nd December 2005, 06:47 PM   #7
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
when you gona to build somethig,implement this also
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 2nd December 2005, 06:49 PM   #8
Zen Mod's Avatar
p2
Old 3rd December 2005, 04:08 AM   #9
Account Disabled
Hi Wuffwaff
The ac-balanced-power is intersting.
By the way, I think that the dc-filtering does the ac-balancing at the same time. Doesn't it . . . ?
jH
Old 3rd December 2005, 12:23 PM   #10
wuffwaff's Avatar
if you mean that after balancing the dc out of the mains is also removed you´re right.
William
dc-filtering-ac-power-stationHide this!Advertise here!
Power line filtering lcsaszar Power Supplies 5 11th July 2008 01:38 PM
UPS Power Filtering/Conversion jkeny Power Supplies 12 13th February 2008 08:30 AM
Power supply filtering Craig405 Solid State 23 9th June 2006 09:28 AM
FA: Audio Alchemy Power Station Four TerryC Swap Meet 0 27th March 2006 03:02 AM
