Humming Power Supply / Vibration - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 30th November 2005, 08:46 PM   #1
Default Humming Power Supply / Vibration
My mixer has an external power supply, plus an external Phantom Power unit.
The problem that I'm having is that the external power supply hums loudly, NOT through the equipment, but through the air. If I put my hand on it I can feel it vibrating.
This appears to be a home built p/s - it has 2 transformers in it, a big one and a little one, and two very large capacitors, along with other circuitry.
What causes this? Is there a cure? This hum gets picked up by my mics and is quite annoying. I've considered making a very long power cord for the p/s and putting it in another room, but first I want to see if it's something simple.
Thanks!
Old 1st December 2005, 04:12 PM   #2
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
it is caused by the transformer .if the windings are not wound tightly enough they start to vibrate and generate noise ...
things that u can do :
-rewind the transformer and make the windingss tighter - not so practical warnish also helps ...
-use a new ,better quality transformer
if you are not living on the edge you are taking too much space
Old 1st December 2005, 04:44 PM   #3
I've been surfing the web quite a bit since I posted this...
read about using "red insulating varnish" on the windings, and also about baking the transformers first to remove potential moisture.
Maybe I'll start by varnishing the transformers and making sure nothing's loose inside the box, and if that fails buy replacement transformers. The whole baking process seems kind of elaborate and time-consuming.
I guess another approach would be to figure out the specs on the power supply and buy a new one. But that would probably cost real money.
Problem: Severe power transformer and choke vibration audio_moksha Tubes / Valves 4 26th February 2008 02:09 AM
tube vibration smak Tubes / Valves 8 19th January 2006 05:25 PM
Major Vibration Phrozen06 Car Audio 4 18th August 2005 02:36 AM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
2 Newbie Questions: matching MOSFETs, and humming power supplies psarin Pass Labs 36 3rd September 2002 10:13 PM
Copyright 1999-2017 diyAudio
