Hi guys,
I'm planning an ultra-portable stereo designed to hook up to a laptop. The plan is to have the DAC (I'm using diyparadise's Monica 2) and a custom class-D amp run off the same 12V switching power supply that the laptop is using, while the laptop runs in power-saving mode operated by a remote. The general circuit tests out, and everything can run without hitting current output limits on the SMPS. However the problem is that there is inavoidably a lot of noise in the PS, whether it's from the class-D or the laptop or the PSU itself. Is there a simple LC-decoupling/bypassing circuit that I can use to decouple the entire noise-sensitive DAC without lowering the supply voltage? What would be suitable values? Thanks in advance |
| Looking for a simple circuit | Skitch72 | Tubes / Valves | 19 | 12th August 2009 07:31 PM |
| Are Polystyrene caps suitable for digital circuit decoupling/bypassing? | homemade | Parts | 8 | 29th September 2006 03:37 PM |
| Help me with simple circuit | valterdaw | Car Audio | 2 | 22nd August 2006 07:15 AM |
| Simple decoupling circuit for DACs? | eVITAERC | Digital Source | 1 | 25th November 2005 10:16 AM |
