small crack in torroid!!future of torroid?
Old 4th November 2005, 07:00 PM   #1
sagarverma is offline sagarverma  India
sagarverma's Avatar
Default small crack in torroid!!future of torroid?
does a small crack has capability to render torroid useless.
the crack is thin but a bit deep.its in inner dia
Old 4th November 2005, 07:06 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Presumably this is a mains transformer.....
As long as no gap exists (causing loss of inductance leading to overheating) there should be no problem IMO. You might be best to clamp it so a gap can't develop. Beware of accidentally creating a "shorted turn" if using a metal clamp arangement.
Old 4th November 2005, 07:12 PM   #3
sagarverma's Avatar
see the pic
this is the use.
in smps.
Old 4th November 2005, 07:17 PM   #4
dhaen's Avatar
I can't see a crack with this level of resolution.
Old 4th November 2005, 07:27 PM   #5
sagarverma's Avatar
see these.
i suppose these show properly.core dia 14cm.
Old 4th November 2005, 07:30 PM   #6
sagarverma's Avatar
and this
Old 4th November 2005, 08:02 PM   #7
dhaen's Avatar
I don't think it will make any measureable difference. Many non-toroid HF cores' fields are completed by sections just touching.
Old 4th November 2005, 08:13 PM   #8
sagarverma's Avatar
but with transformer,my smps not giving any o/p
switcher ok
mosfets.ok
rectifiers,ok
only this suspect remaining.
its giving me headache bec i spent ten times more than what the req core would have costed(its 14cm,only 5cm max req.)
Old 4th November 2005, 08:19 PM   #9
dhaen's Avatar
I don't think it could cause no output.
Assuming it has worked previously...
My checklist would be:
Electrolytic caps - especially if near a heat source.
Open circuit low value resistors.
Open circuit on PCB.
Old 4th November 2005, 08:24 PM   #10
sagarverma's Avatar
hey
thepower supply being used is only 500ma.is it possible that such insignificant supply unable to bring up any appreciable change in flux so as to give o/p????
the test corei used earlier was 4cm dia and it worked.i replaced this core but not working.4cm has no crack@all.
small crack in torroid!!future of torroid?Hide this!Advertise here!
How much to pay for torroid in UK? andyburlow Chip Amps 6 22nd March 2009 07:11 PM
1800VA Torroid to get 40A??? Dominick22 Chip Amps 26 18th July 2006 09:36 AM
Q on torroid mounting weinstro Power Supplies 3 25th January 2006 01:22 AM
Torroid vs. SMPS ChocoHolic Power Supplies 55 21st August 2005 02:34 AM
Torroid coil is humming. jwv3 Solid State 5 12th February 2004 01:09 PM
Copyright ©1999-2017 diyAudio
