Asymetrical Interleaving Winding Technics, Advice Needed!
Old 2nd November 2005, 09:49 AM   #1
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
Default Asymetrical Interleaving Winding Technics, Advice Needed!
this is pretty short question to any of our SMPS pro's on this board, I'm going to design a transformer and would like to know if I can instead of ordinary winding technics use an asymetrical interlieving?
Traditionally it's made up something like this:
Pri: 40 turns ::: Sec: N turns ::: Pri: 40 turns
but I want to do something like this:
Pri: 10 turns ::: Sec: N turns ::: Pri: 70 turns
The idea is to keep secondary windings as close to the "cold" side of the primary winding without loosing to much magnet decoupling between the primary and secondary winding while gaining decreased EMI levels to the secondary.
Cheers Michael
Old 2nd November 2005, 11:39 AM   #2
mzzj is offline mzzj  Finland
Default Re: Asymetrical Interleaving Winding Technics, Advice Needed!
Cheers Michael
Sounds like bad idea, proximity losses etc. increase.
Why not use screening(copper foil) between pri-sec connected to gnd instead of this?
Old 2nd November 2005, 11:44 AM   #3
mzzj,
can you explain what "pxoimity losses" means, and what are those other "etc." losses?
Do you really have practical experiences of asymetric interleaving and have made comparsions with symetrical interleaving?
Cheers Michael
Old 2nd November 2005, 11:49 AM   #4
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
This asymmetrical technique is used sometimes to achieve a given value of leakage inductance, since its value decreases progressively until it gets halved as one of the windings is progressively splitted until two equal halves are obtained.
I can't figure out any other useful purpose for that technique.
Old 2nd November 2005, 11:53 AM   #5
Danko is offline Danko  Hungary
If it would be a push-pull SMPS, like the ones in car power-amps, then the transformer may saturate, becouse ofg the asymmetric currents in the primary. The outer half is 70turns, seven times more, than the other part (thus seven times more resistance), and - becouse the turn's radius is bigger - then one single turn's resistance is bigger, than the resistance in the other half.
Once, I wound a SMPS trafo, like you write: pri:::sec::ri, the primary windings were equal, but the mosfets weren't symmetrically switching. Here's the picture, tagen from the MOSFETs GATE's:
http://sziget.mine.nu/~danko/aramkor...d/12/szkop.jpg
Luckily, the trafo wasn't saturating, becouse I used a current mode controller IC, and the IC can do cycle-by-cycle current limiting.
Best regards, Danko
Old 2nd November 2005, 12:32 PM   #6
Hi Danko,
I was probably not clear with my idea, the both primary windings are connected in series and the middle connection point is floating. Your talk about push pull it's clear case, there even fully symmteric is not enough without DC supervision.
BTW, as a note to your post, it's not so much the resistance that is the problem but the inductance asymetry the increase by the square, for instance 10:70 gives 1:49 ratio in inductance difference.
Hi Eva,
yes it's true that the leakage inductance will be affected especialy if no interleaving is used at all, eg. sec winded adjecant to one side of the primary winding.
My idea is that as long as we have at least one layer of primary the secondary is inside the primary winding and thereby the leakage inductance wont change so much.
My speculation is as soon as the secondary is only on one side of the primary winding the magnetic decoupling is exponentialy decreased and leakage inductance increased.
Like the gapped legg of a ferrite core, once we introduce a very small gap Al dropps dramaticaly compared to no airgap, incresing the gap even further and Al wont change much anymore, the same idea I had with the asymmetrical interleaving winding technic. I don't believe it's linear function of how we inteleave secondary between the primary, but this is also my question to all ya pro's!
I prefer to not use any grounded foils even if that is one technic to use.
Cheers Michael
Old 2nd November 2005, 02:36 PM   #7
mzzj,
Cheers Michael
Proximity effect/losses result when your winding section is a lot more thick than skin depth. Check TI seminars on magnetics/winding desing for detailed info.http://focus.ti.com/docs/training/ca...?sku=SEM401014
No, not any practical experiences as i dont see much point doing that. And what is your problem with screening foils?
Old 2nd November 2005, 08:48 PM   #8
Hi mzzj,
thanks for the link, the material is known for me but a bit forgotten.. I actually attended TI's seminar in Helsinki, I think it was a year earlier or so, when they took up that material for the first time.
But that's the material I had in my mind in my first post and thats what a meant by "magnetical coupling"(not decoupling as I wrote first) between wires.
There seem to be some penalties if I move secondary into an asymmetrical interleaving, but it seem to worsen exponentially so it's probably much better to have at least one layer of primary windings on one side comparing to not interleaving!
I guess I need to make some practical tests.
Cheers Michael
Asymetrical Interleaving Winding Technics, Advice Needed!Hide this!Advertise here!
Advice needed Technics Sl-15 cover removal musicmantech Analogue Source 2 31st July 2009 03:05 PM
Technics SU-G95 schematic needed violentned Solid State 0 22nd May 2008 11:54 PM
Technics su-g95 schematic needed Mailliw Solid State 0 10th April 2007 10:46 PM
Technics SU-G95 Schematic needed Bubbadog Solid State 4 24th March 2004 12:02 PM
The lego-technics transformer winding setup svokke Tubes / Valves 6 22nd November 2003 12:30 AM
Copyright ©1999-2017 diyAudio
