LDO regulator PCB design question - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 27th October 2005, 07:06 PM   #1
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Default LDO regulator PCB design question
The attached image shows 4 variations of a small and simple PCB design for an adjustable LDO regulator such as the LT1084 or LT1085 and would be used to power the smaller Tripath chip amps like the SI, amp3, etc. Can anyone with PCB design experience tell me which layout would be best or how a layout could be improved? The first design only uses the bottom layer (in green). The other three designs use the top layer (red/orange color) for power traces and bottom layer as the ground plane.
I tried to make them as compact as possible not only to keep traces short but because I'd like to house this little fellow in a small chassis with the amplfier. This allows the transformer, rectifier, and filter caps to be situated in their own separate case. The dimensions of the design with the largest ground plane is only 1" by 2". The smaller ones are only 1" by 1.75". The pot allows the output voltage to be adjusted and the small cap right next to the pot is for 120Hz ripple rejection. The smaller bypass caps across the larger bulk caps could be small value ceramics or even MKP or MKT types if the lead spacing is right. No protection diode is necessary with the LT108X regulators for this type of operation so I chose not to include one.
Thanks for any help.
Old 27th October 2005, 08:04 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
All layouts will probably do but groundplanes looks nicer and give you some addtional reduction of impedance, so use groundplanes!
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 27th October 2005, 09:41 PM   #3
Thanks peranders
High Voltage Regulator Design dsavitsk Tubes / Valves 45 21st November 2011 03:05 PM
Voltage Regulator design LM317T 70V to 20V mhamzah3 Power Supplies 4 27th August 2008 09:01 AM
Linear Pass transistor regulator - my design keantoken Power Supplies 49 5th July 2008 10:24 PM
Switching Regulator design Questions fr0st Parts 19 19th November 2007 01:51 PM
Tube Voltage Regulator Design CarlyBoy Tubes / Valves 61 30th October 2006 03:31 PM
Copyright ©1999-2017 diyAudio
