Power supply configuration - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th October 2005, 05:54 AM   #1
Darry is offline Darry  France
Default Power supply configuration
Hello,
Can you say to me, among these 3 configurations (A, B or C), which is the best, the most interesting for the power supply of a preamplifier ?
Thank you for your answer
Darry
Old 19th October 2005, 07:54 PM   #2
I think option B is the one to go for.
You could add a small value resistor before the first cap at location "1". Aim to drop just 1 or 2 volts on each resistor at maximum current draw. Then you have a CRCR supply which is very low in hum and hi freq artifacts.
Look up snubbers for both the rectifier diodes and for the PSU output as well as film and ceramic bypass for the electrolytics.
Your pre will really appreciate a good DC supply, but keep it very compact to reduce track and wire lengths.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 20th October 2005, 09:30 AM   #3
jlm is offline jlm  France
It seems to me to have read, I do not know any more on which forum, than John Curl with CTC Builders use the B configuration.
Old 21st October 2005, 07:29 AM   #4
Hello,
I would like to recover these comments of John Curl.
What forum ?
Configuration power supply Darry Solid State 3 21st October 2005 07:27 AM
Help on using LM319 in Single Supply Configuration Workhorse Class D 4 13th December 2004 12:46 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 02:30 PM
Power rating for push pull configuration question miked15 Tubes / Valves 4 15th May 2002 03:50 AM
Copyright 1999-2017 diyAudio
